I know about the Modern Spare. I'm searching for info on the Vredestein Space Master, and if anyone has tried to fit it on a Tesla. The only fitments seem to be German cars.
TYPO=Should say 5X120 for the model S & XBring this thread back to life. I have a Model S Plaid--and was looking for a 5X120, but, in researching lug patterns, I came across some 5X114.3 like used in the Model 3 & Y. It seems Maserati had one. The luh pattern is correct, but not sure on the brake caliper clearance. I will lust a few of the links I found. Here is an example.
https://www.ebay.com/itm/234466144074
Lug cross reference
Bolt Pattern Cross Reference - What Wheels Fit?
35 Cars that have a 5×114.3 bolt pattern
35 Cars That Have A 5x114.3 Bolt Pattern
Please post if you find a suitable 5X129 for the S & X, likely needs to be 19" or larger.
I am glad I found that one for all you Model Y people! When you are searching around see if you can find one for my Model S Plaid. It is 5X120.HOORAY! IT FITS! VredesteinSpaceMaster from a 2017-2021 Maserati Levante.
It bolts up perfectly, (both back and front) not even close to any issue with brakes or suspension parts. Inflates as designed, car is perfectly level when the tire is inflated. Drove gently around my community (haha...some harsh concrete cracks) and up to 40mph, and noticed zero difference in ride/handling (drove with it installed on the front).
The bore of this VredesteinSpaceMaster is very slightly larger than the OEM Apollo/Gemini wheel, so in fact, while installed, it will be "lug centric" rather than "hub centric". The tapered lug nuts didn't cause the wheel to shift when installing, so when the wheel was resting on the hub, the difference in alignment is miniscule.
GOOD NEWS, for ME: $319 including shipping, clearly brand new, never installed.
BAD NEWS for y'all, unless they start showing up on Ebay: Maserati dealer price is...gulp...$909. Sorry about that.
The tire will fit vertically behind the rear bumper. I'll need to cut out a rectangular hole in the trunk floor. The tire will be slightly above the trunk lip, but the hatch closes easily w/o any issue. I'll investigate how to secure the wheel to whatever structure I find behind the trunk liner.
I'll post photos when it's all set up.
