Wall Connector install for rear entry - question
I did finish my install. I ended up using 6/2 nm and used the corresponding 3/4” nm clamp. Needed to wallow out the hole in the wall to clear the nm clamp but it installed very cleanly.
Hey I’m about to do a very similar install rear entry and had the same question - do you mind sharing what nm clamp you used? Since you used 6/2 nm did you end up just doing 50 amp breaker and charging at 40a? Thx.
