Wall mounted charger
Moved into new house with existing home charger TPN: 1011831-99-B and TSN: T13A0002269. My 2021 Tesla model S will not charge on the high power wall connector. Previous owner of the home had an older model S and says the charger worked fine for him for 5 years. What must I do to get it to work?
I had a problem charging on a Gen 2 wall connector. I never solved it because it was not my wall connector. Is it on a 100 AMP breakers? If it would have been my wall connector I would have tried setting the wall connector at 48 AMPs and try that.
M
PS - The charger is actually in the vehicle.
Probably incompatible with MCU2:
Reactions: Rocky_H
I am pretty sure it's this. There is a known incompatibility of old wall connectors with the newer vehicles. Some kind of communication signal mismatch that Tesla never worked out. Their fix was to replace the old Gen1 wall connectors with Gen2 wall connectors. So now I guess that would be the Gen3 (I'm sorry) since they don't sell the Gen2 anymore.
Reactions: UncleCreepy
that was going to be my suggestion.....I was on 100a panel and had to charge at 40a.....I upgraded panel to 200a and changed dip setting to allow for 48 a charging...works fine......since you have 100a, you did the right thing also, the Gen 2 charger that has the NEMA 14-50 plug has known issues....will cut down from 40a to 30a when it senses heat in the cable or connection.....Tesla admitted they were bad and gave me new hard wired connector.
