Wanted: Electrician recommendations for Sammamish
they contacted me after I checked 'yes' to have solar city contact me with the pre-mvpa paperwork -- and they called within a day or two. I can PM you my contact at solarcity maybe that will help -- the phone number of the electrician I also have but probably too far from proper procedure
Please do, ahimberg. Understood re: the phone number, but you could call him and ask first. ;)
50A is as much as a NEMA 14-50 outlet can use (and in fact for charging, you will only pull 40A of that). You only need a higher circuit if you are going to install a Tesla charging station.
Both of our EVs have used 14-50 outlets for years. It's always been enough for us.
Solar City electrician coming out tomorrow to install (assuming all goes well) a 6-50 and 14-50. The 6-50 being a temporary that will turn into an HPWC at some point.
My plan long-term is to throttle back the Model S to 40A whenever the 14-50 is in use in parallel.
Hopefully I'll have good news to report tomorrow night. But will likely report news either way. ;)
I received a bid to install a "50A dedicated circuit NEMA 14-50" for $395 in my garage. I live in Bellevue. I am getting it installed next week. Is the 50A capacity enough? I saw some mention of 80 amps in some posts.
your config (in the delivery thread) doesn't have you getting twin chargers, which you would also need to take advantage of something higher. (and yeah I doubt you'd ever need it as every morning you'll be full nomatter how much you drove the day before... check out the tesla charging page for estimates on how long it takes to charge, if you think you'd ever need to regularly drive a lot, go home & charge and drive some more fairly immediately -- that's the risk)
Thanks to everyone for the info.
Here is the electrician I am using. It is Northwest Electric and Solar:
* site: Northwest Electrician and Solar
* phone: 206-356-0601.
I have been working with Derek White. Note that I had a coupon from Angie's List so your price may vary. Also, he has not done the work yet so I don't know his work personally but they are highly recommended at Angie's List -
Francis
My electrician just finished my new NEMA 14-50.
I've used him for all my other properties electrical work. Good price, clean work. Takes pride in what he does, a rare trait among subs nowadays.
Here's a pic of my new setup.
Here's his info:
77 Electrical
206-599-9146
Sent from my iPad using Tapatalk HD
He had to move couple breakers around to make room for the 50amp circuit breaker.
Cut hole in drywall for the receptor (14-50R)
Short run (in my case) from panel to just directly below.
He used a wire that's rated for 72 amp, that way it wouldn't run hot. He didn't know my MC240 was only capable of handling 30amps so it's a bit overkill but who knows what I'll install in the future.
That for $275 plus tax.
Here's his info:
77 Electrical
206-599-9146
I just used 77 Electrical based on Jackyche's suggestion. He did good work. Attached is a pic from my setup. I had him run conduit around the door in my garage so I could tuck the cable away in the corner (anywhere else would block our ingress/egress to the door you see pictured). The total was ~$550 or so.
Update - SolarCity is coming back next week to change my 6-50 to a 14-50 (and I guess the others they did in the seattle area). I forgot to ask if they're charging for this, I was assuming not -- and just the other day got the bill for the original install, maybe I should have waited longer to pay it.
Interesting. When I had my SolarCity visit, he came with a 6-50 despite me explicitly saying I wanted a 14-50. He ended up making a trip to the hardware store to get a 14-50R since he didn't have one on hand.
(I'm planning on installing a separate line for the HPWC, not upgrading it from a 6-50R but rather leaving the 14-50R for friends and/or a second vehicle in a few years.)
SolarCity called me about this as well. I followed up with Tesla and they confirmed the 6-50 is ok. You just need to make sure they include the correct adapter with your car.
I figure if the 6-50 works they I don't need to risk someone messing around with the wiring again and breaking something.
Tesla also mention the 6-50 is what people are using who are getting the HPWC. I'm not in the market for it, but I guess I'm future-proofed.
ah, I was under the impression that they didn't want to give out 6-50's except to those waiting on the HPWC or something (at least for now til they start selling a large array of adapters). the 14-50 seems more standard though, if solarcity is going to charge me for this maybe i'll not do it
Talked to my delivery specialist about it. He is making sure the right adapter is included with the car. It's an extra $45.
