and then about an hour later....2020.12.5. Exciting.![]()
Is there anyway to force an update? I've been stuck on 2020.8.3 for over a week now but have only had the car for 2 weeks
Get used to it. Some times you will get update almost right away and other times it will seem like you are stuck on an older version forever. There is NO method to the madness of getting an update.Thanks guys. I'll just have to be patient. Not easy though when I see all the reports on 2020.12.5
So you went from the 2020.8 stream of updates, to the 2020.12 stream. These two seemed to be running in parallel for a while.and then about an hour later....2020.12.5. Exciting.![]()
Hopefully this suggests they are now merging.
My car has been asleep for over a week now because I've been stuck at home. I just woke it up for the first time yesterday because I finally got approval to turn on my solar panels and I had to set those up in the app which defaulted to my car and woke it up before I could switch over.
If the car is always asleep I wonder if it'll ever update?
No, I just got 8.3 as well on the new X long range plus. I guess it has to go through several updates.I was stuck on 8.1 for three weeks while reading about all the new versions out there. For no good reason, I switched the car’s ‘update’ switch from ‘advanced’ to ‘normal’ (I forget the actual terms used in the car) and boom! the car said I could update to 8.3 toot sweet.
I suspect I’ll have to live with that version for a while since I hear that 12.5 is strictly for Yanks so us Canucks will have to wait it out.
