I’m in Canberra and no idea in the difference in our water quality, but I have to dry my car with a drying towel to avoid the lovely white spots/rings which are most visible on the windows for me (as MY is white). But my dark blue Audi gets a dry, or sometimes a blow down with a clean battery powered yard leaf blower. If not the white rings abound.This is for SA residents where we have awful water. Just wondering if anyone is using a whole of house water filtration system, and if so, does it eliminate the need to dry off your car to ensure residue spots don't settle on car
Will not get rid of water spots on carwhole of house water filtration
Yes, did a lot of googling last night, water filtration won't sort out the issue. So quickst, putting vinegar in a bucket of water then splashing it on car as a final rinse will alleviate water spottingWill not get rid of water spots on car
Only the following will:
Reverse Osmosis / distilled water
Water softening - resin beads and brine tank
Simply adding a bit of vinegar to the final wash.
Dry the car with a chamois before the water drops evaporate
White car.
The water softening - Tank of water with resin beads have a negative charge and absord the positively charged calcium and iron minerals. The used resin beads are reactivated by placing the beads into a brine tank (very salty water). The consumable is salt. But then where are you going to dispose of the brine periodically?
Throw it in the sewerage. Worst things go down there every day around 10am.The consumable is salt. But then where are you going to dispose of the brine periodically?
My water down south of adelaide is shocking.This is for SA residents where we have awful water. Just wondering if anyone is using a whole of house water filtration system, and if so, does it eliminate the need to dry off your car to ensure residue spots don't settle on car
I was looking at the big boi, which one do you have. Is it quicker to use than towel dryingMy water down south of adelaide is shocking.
I did look into putting some filters on the house supply to also assist with all the other washing machines etc.
With the car i wash it in the shade, and then use a big boi filtered air blower to dry it. The ceramic coating really helps here. Sometimes ill then go over it with one of those soft green car wiping towel things,
Mine is Stealth Grey so its pretty obvious with water marks, after the advice on here to get the big boi blower ive been stoked.
I have the Big Boy Mini. It goes on sale every now and then at Repco. It could do with a longer cord, but i just plug it into a short extension lead .I was looking at the big boi, which one do you have. Is it quicker to use than towel drying
Wow they are pricey!I have the Big Boy Mini
We in Adelaide love upsetting the neighbours so Big Boi it is. So, I ended up getting my money back from those bozos that did my Paint protection. The car is now at a reputable place who need it for 2 days. When I got there they put the light over the paintwork and there were heaps of minor scratches on the duco. So it needs a bit of paint correction. They said it was probably caused by washing the car. I told them I havent washed it yet. So it was all caused by the bozos applying the coating on my car without preparing it first. I also got this mob to re-do the window tinting again, as the Bozo mob stuffed that up as well.Wow they are pricey!
A drying towel (at $30) and 10 mins of my life to dry feels like the better option. And you’d take the about the same time with the blower as well.
Each to their own.
I also enjoy washing the car and seeing it sparkle!
I don't have town sewerage. Only onsite septic treatmentThrow it in the sewerage
I have a couple of these i bought on special too, very good. Ive found it useful to throw them in the dryer after washing them to keep them soft before using them. Also helps remove any lint/pubes.This is a well proven solution for this issue, buy it when it's on special.
The Big Green Sucker - Luxurious and plush drying towel.
The extra "give" in this plush drying cloth means you won't be pushing dirt and grime back into the paint, thus eliminating swirl marks or scratches from ever occurring, making it perfect for the more sensitive or delicate paintwork of older or unrestored classics.www.bowdensown.com.au
If its brine, can you put some olives in it?I don't have town sewerage. Only onsite septic treatment
hopefully they do the job to your satisfaction and you get to relax and enjoy driving it soonWe in Adelaide love upsetting the neighbours so Big Boi it is. So, I ended up getting my money back from those bozos that did my Paint protection. The car is now at a reputable place who need it for 2 days. When I got there they put the light over the paintwork and there were heaps of minor scratches on the duco. So it needs a bit of paint correction. They said it was probably caused by washing the car. I told them I havent washed it yet. So it was all caused by the bozos applying the coating on my car without preparing it first. I also got this mob to re-do the window tinting again, as the Bozo mob stuffed that up as well.
Putting it in Town sewerage might also be a bad idea as a lot of systems use bacterial processing systems / though depends on overall volume. [/off topic]If its brine,
