I noticed that my Model S charge port flap was partially filled with water. But I had no idea how it got there.
![](https://teslamotorsclub.com/tmc/data/xfmg/thumbnail/122/122655-66aba8271bed0fc1de13ae5ff8fe40e1.jpg?1716714566)
The rubber seal inside was a bit lose and came-off easily. It revealed two pins and a tiny hole, which I widened with my drill. In addition, I drilled a hole at the bottom, in hopes the water would drain (it didn’t).
![](https://teslamotorsclub.com/tmc/data/xfmg/thumbnail/122/122656-3697b5db51e85264f1e646a9afb41318.jpg?1716714570)
Fortunately, I have a compressor in my garage, for maintaining tire pressure. It came with a nifty little nozzle, almost as thin as a syringe (ball inflator). I blasted pressurized air into the flap, and water started draining out.
![](https://teslamotorsclub.com/tmc/data/xfmg/thumbnail/122/122658-c9f2894247bc7769f6411f59aa212c39.jpg?1716714584)
Then I cleaned all surfaces and reinstalled the seal. I used a special 3M VHB double sided tape, as I was worried that trim tape may be too thick.
![](https://teslamotorsclub.com/tmc/data/xfmg/thumbnail/122/122659-2d5126268c8eef70cd7251d8a7c45160.jpg?1716714586)
The end result is very satisfying.
![](https://teslamotorsclub.com/tmc/data/xfmg/thumbnail/122/122660-d2d8defa8a4c9ac4bca9cd5cc005afe9.jpg?1716714591)
