That seems quite good, and about what is expected if the battery mostly is at or below 55-60%.It comes out to 72kwh. I'm at 51% charge right now though. Car just turned 4 years old. Is that good or bad?
Recently there was a massive study performed on some 12.5k cars that were mostly supercharged. The conclusion was there was no more or less degradation than those not being supercharged.I wonder if people are eventually going to start paying attention to this calculation when purchasing used cars. There are people that only supercharge to 90% every day and you would want to pay less for a battery treated like that.
Are there any such studies that show thousands of cars being tested to show otherwise?
Point is they have conducted a study that says the harm is no more or no less. Your additional questions are all valid but the same could be asked of level 2 charging but there's no such study. A colleague at work is forced to SC is car every couple of days vs one who adheres to strict charging charts at home. They've both degraded equally. YMMV.I read a few articles on that study from recurrent. The articles make it sound like supercharging is the same but I have some questions. I am learning a lot about batteries lately lol.
They are comparing these cars but how many cycles of charges and what maximum charge level?
We know charging to 90% degrades the battery a little faster alone. Surely supercharging to 90% everyday is worse than just parking in my garage at 50%
Then there is the question of failure rate. They talk about battery degradation but not failure rates. It doesn't matter if your battery has the same capacity if it totally fails sooner. What was the failure rates?
I am a bit sceptical from that article, judging the wear from supercharging by (most probably) range data from cars.Point is they have conducted a study that says the harm is no more or no less. Your additional questions are all valid but the same could be asked of level 2 charging but there's no such study. A colleague at work is forced to SC is car every couple of days vs one who adheres to strict charging charts at home. They've both degraded equally. YMMV.
Yeah that seems to match my experience.In my experience it took several weeks of letting the car sleep at different charge levels before the BMS recalibrated. It's a gradual process, not something that happens instantly as soon as the car sleeps then wakes once.
Also FWIW I can roughly match the EPA range figures when driving around my city. I get that for certain driving styles it can be impossible, but it can be achieved for some people. Living in a warm climate where you don't need the heater and traffic is pretty quiet makes a big difference.
The most efficient speed is around 70-80km/h. If you cruise at this speed and never stop you can do pretty much double the EPA range. This obviously isn't realistic driving though. In my city I spend a lot of time on quiet roads cruising at those speeds, so when you then take into account things like traffic lights, corners, etc, I can roughly get EPA quoted range when driving gently.The closest I ever got was on the highway driving the speed limit on ideal weather\road conditions, but it was still higher (270-280 in the summer). I wonder how much variety might exist from manufacturing\alignment differences?
The best efficiency is between 20-25C temperature, if looking at logs from for example teslafi. No (or almost no) AC power is needed to keep the cabin temp.Even in the summer I was never able to hit rated efficiency with cautious driving. The closest I ever got was on the highway driving the speed limit on ideal weather\road conditions, but it was still higher (270-280 in the summer).
Probably not much from motors/battery etc.I wonder how much variety might exist from manufacturing\alignment differences?
In moderate temperatures, I have the climate control in fan only mode (AC off, temperature set near the low end to avoid heater use). Perhaps that may be part of why I find it easy to exceed the rated economy in 65mph highway driving.The best efficiency is between 20-25C temperature, if looking at logs from for example teslafi. No (or almost no) AC power is needed to keep the cabin temp.
I recently got about 300 miles on my 18 M3LR before I had to charge. I usually drive between 65 and 70 mph on the freeway with AC on manual on 5 speed. I agree with you about driving habits and range.In moderate temperatures, I have the climate control in fan only mode (AC off, temperature set near the low end to avoid heater use). Perhaps that may be part of why I find it easy to exceed the rated economy in 65mph highway driving.
If you have the climate in automatic mode, either the heat or AC is running most the time, which tends to be a fairly useless waste of energy if the temperature is already in your comfortable range.
I wouldnt offer my comfort for that, but its of course a personal choise.In moderate temperatures, I have the climate control in fan only mode (AC off, temperature set near the low end to avoid heater use). Perhaps that may be part of why I find it easy to exceed the rated economy in 65mph highway driving.
