I believe I have the right sized PV system for normal daily use of power. I’m able to fully charge a Powerwall and Model 3 during the morning, and in the afternoon I turn on a Spa pump which primarily uses the solar to run until dusk, and which point the Spa turns off and the loads are serviced by the Powerwall.
The problem is my load tends to vary at times during the day, when for example the water heater turns on, or a cloud passes over. In the early morning, I’m only drawing 400 watts. By 9am that goes up to around 1KW, but it will spike from time to time up to 6KWs. In the afternoon, my Spa draws 6KWs just on its own, and the loads can spike as high as 11KW for a few minutes. The grid, acting as a buffer, handles all of this nicely.
What happens when the grid is not available? So, if I have a power failure before the battery is fully charged, but the PV is generating 8KW, what will my single Powerwall do? Once it’s fully charged, I know it can turn up the frequency forcing the PV offline, but when the PV is putting out more than the battery can accept, will it do the same? I’ve heard the Powerwall can actually accept more than 5KW for short periods of time; how short, and how much?
