The rims are 19” x 8.5”.
Using willtheyfit.com, comparing to stock wheels, they should be similar in all dimensions, but 10mm closer to the car / strut.
If you have the non performance brakes, the stock offset is 40 mm not 35. The data that you're getting from the website probably assumes that you're talking about the performance brake car. The rotor hat on that is significantly thinner, moving the wheels in board almost 5 mm. So these wheels would actually move the wheel and tire assembly inboard 5 mm, if you have the non performance brakes again. You should be able to accommodate that, but it's not ideal. If on the other hand you you have the performance brakes, then you are talking about 10 mm closer to the strut which is cutting it close. It's still will probably fit but it may look a little funny with the wheels tucked in a full centimeter.
