What kind of plug is this, and can I buy an adapter?
Discussion in 'Model 3: Battery & Charging' started by clicketyclack, Nov 17, 2018.
  1. clicketyclack
    clicketyclack Member
    New Jersey
    I'm renting a house and saw the attached plug in the garage, was just curious if anyone knew the kind of plug this is and if there is an adapter available.
  2. marksvend
    marksvend Member
    Issaquah, WA
    • Informative x 2
  3. CCIE
    CCIE Member
    CT
    • Informative x 2
  4. mikeinanaheim
    mikeinanaheim New Member
    La Habra, CA
    Means with adapter mentioned above, you get get more efficient power usage and faster charging than 110V. Perfect.
    And probably best charge rate for long battery life.
  5. eprosenx
    eprosenx Active Member
    Beaverton, OR
    What others have said about it being a 6-50 is correct.
    I would look in your panel to see what size circuit breaker it is on. Most likely it is on a 40 or 50a breaker, but it could be on something smaller. Anything less than 40a and you won’t be able to charge at the max speed of the UMC.
    You are very lucky to find a rental with such a great charging option built in!
    Probably was for a welder...
  6. Taric25
    Taric25 New Member
    MA
    Pardon, doeando the NEMA 14-60 charge faster, since it provides 60 amps instead of 50 amps?
  7. Taric25
    Taric25 New Member
    MA
    doesn't*
  8. marksvend
    marksvend Member
    Issaquah, WA
    The Mobile Connector (gen 2) that comes with the Model 3 is only capable of 32 amps max. The gen 1 Mobile Connector that you can buy from shop.tesla.com can charge at 40 amps maximum. A Tesla Wall Connector does 48 amps, but is typically hard-wired by an electrician.
  9. eprosenx
    Beaverton, OR
    Exactly.
    To add to this: I know of no adapter for the UMC (gen 1 or 2) that would let you plug into a 14-60. Also, I have never actually seen a 14-60 in my life... I know of no application that uses them.
  10. Taric25
    Taric25 New Member
    MA
    I know some electric ovens use them.
  11. clicketyclack
    New Jersey
    Its a 50amp circuit so I am golden
  12. MorrisonHiker
    MorrisonHiker S 100D 2019.20.4.2
    Colorado
    My brother has a 6-50 outlet in his shop that I used for charging. We failed to check the fuses first and an hour after I started charging, the fuses blew and shut things down. Since it was Christmas Eve, I had to wait another day and a half to find a store that sold the right fuses. We replaced them and then I charged at 32 amps instead of 40 amps and didn't have any problems after that.
  13. eprosenx
    Beaverton, OR
    What were the fuses rated to? 40a?
  14. MorrisonHiker
    Colorado
    I think they were 40 amps, IIRC. Since I was used to charging at 40 amps at home on a 50 amp breaker, I incorrectly assumed his 6-50 outlet had a 50 amp breaker as well. When things stopped working, we investigated and found the 40 (?) amp fuses:
