tnt1971
I don't get this. We're not getting up in the middle of the night to breastfeed our battery.
With all of this talk about ideal charge percentages, i'm curious where the software limited S60 fits into the mix. Since the current S60 has the 75 KWh battery and limits capacity (80 percent for you math majors), this changes the equation.
You would have to be able to see every cell's (or at least every module's) voltage to tell.II have never seen the battery "out of balance".
I have one of the last 85Ds with about 11,000 miles now. I have done 2 range charges in the car's life (one to 100% and one to about 97%.) Most days I only charge to 50% and when it is really hot, I keep it between 20 and 40%, except when I need more. I am ashamed to admit it, but as one funny post said I breastfeed my battery.
I have never seen the battery "out of balance". I have the Visible Tesla software, and I consistently get the equivalent of 275.2 miles on a full charge or the appropriate fraction. For example, when I do a 50% charge I always get 137.6 miles, which is exactly half of 275.2. I don't know if this was something on the early cars, but again, I have never seen where my battery gets a different range at the same charge percent.
50% on a daily basis will throw the pack out of balance and it will appear that you have lost a lot of range. 90% does no harm based on the many posts in this group. Neither does the occasional 100% charge--just don't leave it sit at 100%. The 50% is really for long periods when you're not driving the car.What are the benefits of only charging to 50% as opposed to 90% on a daily basis. Will it damage the batteries in the long run if I always charge to 90%?
All you need to do is resume charging at 90% and it slowly go back into balance. A 100% charger will rebalance the pack faster, but it's only suggested that you charge to 100% if you anticipate needing all the range and don't leave it at 100% for too long.Thanks for the info. If a pack goes out of balance is there some procedure (either done at home or at a service center) that can correct it?
The procedure I use is running it down to 10% then a full 100% charge. The balancing kicks in around 93%.Thanks for the info. If a pack goes out of balance is there some procedure (either done at home or at a service center) that can correct it?
The balancing circuits activate at 93%, so just charge to more than that. Once activated they will stay activated until complete regardless of charge level or trip length. (WK057 did a lot of research and experimentation to find this out). My experience is that it takes several cycles to regain the "missing" miles.Thanks for the info. If a pack goes out of balance is there some procedure (either done at home or at a service center) that can correct it?
Roblab, you're talking apples and oranges. Your 90 has a 90 kWh battery so you appropriately avoid charging it to 100% except for trips. AustroTom's 60 has a 75kWh battery. When he charges to 100% it's really only 80% of the full battery. If and when he pays to unlock the full 75kWh, then he'll want to only charge to 90% too.Since we don't need to charge to full, I charge to 90%. Since the car limits charging speed somewhat severely as the battery fills up, it seems obvious that it doesn't like full charge. The car also tells you that charging over 90% is for trips. I guess you can fill to 100% allatime, but since the battery is the most important and expensive part of the entire car, most Tesla owners try to be gentle with it. Many people who buy a used Tesla from an individual want to make sure the battery has been babied.
My 2 cents. I read through this thread and many others and there are many different opinions. I emailed my service guy at Tesla and his response was, "plug in nightly if possible, full charge isn't a problem on occasion - charge to 80% for daily driving when range is not needed."
I know that is one tech's opinion that works for Tesla and others may say different. However, that sounds reasonable to me so that's what I'm going with.
We just got our S60 about 6 weeks ago (2,800 miles so far), and we were told by a service technician and sales staff that it is ok to charge the 60 to 100% pretty much always, as the last 15KW are dormant.
So that's what we do, (unless somebody comes along and refutes this claim )
