When purchasing tires at COSTCO or having your wheels balanced, remind the technicians to use gram weights as opposed to ounce weights. The gram weights are thinner. I heard a knocking noise when making turns so I took the car to Tesla thinking I had a bearing going bad. After investigating Tesla replace the ounce weights with gram weights and the problem was solved. I just replaced my tires today (after 57000 miles; they had just reached the wear bar) and as I drove away the knocking sound happened again. I immediately took the car back and the guys rebalanced the wheels with gram weights; problem solved!
Edit: As I think about it, I suppose it is good advice wherever you have your work done. The thick weights will scrape on one of the suspension nuts in front.
