- - - Updated - - -
What would you recommend besides some tightly strung electric tape?
...again, lots of pre-existing info on these forums for you to search out and peruse.
In my case, what I did was to cut the cigarette lighter plug off of the Blackvue power cable, preserving the in-line fuse holder. I stripped back the red & black leads on the power cable, twisted the bare wire, and tinned the leads (...if you don't know what this is, ask your geeky friends with a soldering iron). I then popped open the connector under the microphone speaker (the one in your photo), verified the voltage and polarity with a voltmeter, and carefully laid the tinned leads on top of the existing connector pins. I then snapped the connector closed. I then checked with a voltmeter that I had 12v and proper polarity at the right angle connector. Fish the cable/connector out of the headliner, udner the rear view mirror mount, and to your Blackvue. The original connector is still available for whatever accessory TM comes up with later. The Blackvue gets fused always on 12v power. All good.
Make sense??
