Which mototrs will truck get?
woodguyatl
446
359
GA
Edit: Mods, any chance you can fix the thread title for me?
Has anybody seen any information about which motors each of the three truck versions will have?
David99
4,850
7,021
Brea, Orange County
Here is how I understand it. Inductions motors have a certain 'slippage' which is by design. Permanent magnet motors, like the ones introduced with the Model 3, don't. The rotor follows the generated magnetic field exactly. Two of those motors don't work together as efficiently hence Tesla always combines a induction motor with a PM motor in all their current dual motor cars. The slippage of the induction motor compliments the 'rigid' nature of the PM motor. The rear motor is PM and does the majority of driving taking advantage of the higher efficiency. The front induction motor kicks in when extra power is needed. The dual motor version of the truck will probably have this configuration.
Tri-motor cars will be a challenge. Maybe Tesla has figured out how to run three PM motors efficiently together now. Or maybe they will continue to combine both motor types like they do now. I would think it might be difficult to have two PM motors on the back wheels. They spin at slightly different speeds unless you go perfectly straight (which is rare). Having two induction motors on the back wheels would fix that issue. The front motor would then be PM and would get priority most of the time in normal driving to take advantage of the higher efficiency.
Again, that's all my theory and is based on what people have told me about the different motor types. Once the first tri motor cars are out, we can only speculate.
woodguyatl
446
359
GA
This is very helpful. Thank you for taking the time to share your thoughts. Off I go down the induction vs PM motor rabbit hole.
David99
4,850
7,021
Brea, Orange County
Tesla is using a 'reluctance' motor in the Model 3 (in the rear). It is a very efficient variation of the permanent magnet motor. I'm no expert but I was told so far no one has used that type of motor in an EV because it is very difficult to get it working well for an EV where you have a large spectrum of power and RPM. The brilliant minds at Tesla figured it out and made it work.
Reactions: SmartElectric
Seagrave7
31
12
Los Angeles, CA
The current batch of dual motor Raven-powered Teslas utilize a Model 3 rear motor mounted up front and a Model S/X motor in back. Per MotorTrend. I know I saw somewhere what the Tri motor is made up of but having a hard time finding where I read it in the last few days.
