I understand that the purpose of the foam inserts on the tires that typically (always?) ship with the S, X and 3 is to reduce road noise. (Is that true? Or is it for efficiency?)
Why is that necessary? In my Model 3, I don’t seem to have a wind noise issue but I get quite a bit of tire noise with the 19” OEM tires. Would it be that much worse without the foam insert (which I assume is there?)
Is it because there is less / no engine noise? Is it not to reduce noise but to increase efficiency? Why don’t all cars use tires with foam inserts if it makes them “quieter”?
Just wondering.
Just wondering.
