Why I can't select fixed offset on fsd?
Can anyone explain why I can not select fixed offset in fsd to make it 5mph over speed limit? Photos attached.
Thx,
Ian B
Because that is no longer an available option. (As called out in the release notes.)
I think the idea is that it is generally inappropriate in the wide range a speeds that FSD is designed to be used in. (Setting 5 MPH over, is the same as 25% over when you are in a 20 MPH zone.)
Reactions: MrIanB
