WIFI Connection
Hmmm, too little information. Perhaps say what kind of WiFi equipment you have and signal strength in the car when it is connected. I've seen some cases where if the signal is weak to begin with, then if the car loses connection, it says on cellular. Not always the case. Lots of variables.
Reactions: P85_DA
Like Silicon Desert said, it may be a signal strength issue.
Wifi antenna is in the passenger side mirror from what I've read. I can have great signal strength on my phone but the X only has 1 bar.
Don't even get me started on the app. Can connect anywhere but at home.
I was using a mobile router to update the navigation database, but it managed to install everything during the night, so since i have the premium connectivity package until the next navigation database update i'm set! Thanks!
The WiFi doesn't stay connected. It only connects for a little bit after the car stops and then disconnects. It only stays connected if there is something to do.
More specifically, that portion of the computer shuts down to conserve power.
