Not sure if this is happening to many others, but my S will disconnect from WiFi every half hour or so. Usually it reconnects, but some times it just gives up. The APs at both houses are Cisco, so that may have something to do with it, but they're different generations and on different IOS releases. I've also experience the issue at my friends house with the standard Pace 5268ac AT&T uses.
The error I get on the AP is
Interface Dot11Radio0, Deauthenticating Station xxxx.xxxx.xxxx Reason: Previous authentication no longer valid
Searching the error typically pulls up disabling Aironet extensions, but that didn't have any effect with the car.
Further sniffing reveals it's a timeout issue between the car and AP, and only occurs if there's no traffic. My solution was to run "watch -n 15 arping -I eth3.1005 10.1.5.100 -c 1" in a screen session on the router. This keeps a few packets going back and forth every 15 seconds, we have to use ARP since the car dosen't respond to normal pings. Got it to finally stay connected for more than an hour at a time, 16 hours so far.
Hopefully I'll get a firmware update soon
