Will 19"S wheels fit on M3?
Discussion in 'Model 3' started by kgclark, Sep 26, 2017.
Tags:
  1. kgclark
    kgclark Member
    Cazenovia, NY
    Hoping to be able to buy a set of 19" take-offs from a Model S to use for snow tires. Does anyone know if the wheels and TPMS will be cross compatible?
  2. FlyingKiwi
    FlyingKiwi Member
    Auckland, NZ
    It is rumored by one of the companies that makes aftermarket wheels for Teslas that the Model 3 uses a different stud pattern - 5 x 114.3 mm (a common pattern for Japanese RWD/4wd performance cars), and the Model S and X use 5 x 120mm (same as BMW). If that rumor is correct they wont fit.
  3. Tsportline
    Tsportline Vendor
    Los Angeles, California
    #3 Tsportline, Sep 28, 2017
    • Informative x 2
  4. igotzzoom
    igotzzoom Supporting Member
    Laguna Hills, CA
    The main things are the bolt pattern, offset and back-spacing. Also brake caliper clearance. That will determine if they will fit.
  5. Garlan Garner
    Garlan Garner Well-Known Member
    Chicagoland
    Tesla should provide inserts for their Turbine wheels for the model 3. Just like they do with their aero wheels.
    This is an overlay that I would like.
