XPEL I presume is the brand for windows as well.XPEL is good. When XPEL is installed well with wrapped edges, you won't see any downside really on a red car. I'm sure others can contribute more.
What brand is the window tinting film?
Michigan has strict rules but police will only pull ya over if they cant see you at all or if the windshield is noticeably tinted.If legality is important to you, it depends on the state you are in.
I chose to go with 30% front and 15% back. The tint shop I visited measured the factory back tint first and added another, lighter tint to get the rear tint down to 15%.
The back is about 24% from the manufacturer, so 25–30% on the front would match if you want an equal amount of shade.
However, the rear is only smoked glass, not actually tinted, and offers no UV protection.
The shading in the rear can not be removed, but you can have a film installed over it. If you are not wanting to add much extra shade you can use a 75% shade of film to block out the heat and uv but not add any additional shading to it, of you can add other shades to make things darker if you would like.Has anyone removed the rear tint to upgrade it? I was planning a ceramic tint all the way around but not sure if it’s worth replacing the rear windows tint as well.
For those considering tinting the windshield… consider also that the next day you can get a chip and your money is wasted… I had that missfortuneThe shading in the rear can not be removed, but you can have a film installed over it. If you are not wanting to add much extra shade you can use a 75% shade of film to block out the heat and uv but not add any additional shading to it, of you can add other shades to make things darker if you would like.
We tint several of the Model Y vehicles and majority of our clients do choose to do all the glass.
If you have any questions on Tint, PPF, or Ceramic Coating please let me know and I am glad to help you out.
Travis
949-522-6287
You are correct, no one can control when a rock chip will happen. No one can also control an accident either but that is why we have insurance as well so things can get fixed and repaired.For those considering tinting the windshield… consider also that the next day you can get a chip and your money is wasted… I had that missfortune
Concur. However windshield chips are more common than accidents....I think. Just something I had not considered before spending money on it. In Michigan however, without much sun compared to southern states, windshield is not as impt to tint. IMO.You are correct, no one can control when a rock chip will happen. No one can also control an accident either but that is why we have insurance as well so things can get fixed and repaired.
If you live in norther states no need for front windshield tint. I had then apply a UV ceramic protector that also reduces heating of pannels but not tinted.I'm also thinking of at least getting the front windows tinted to match the rear windows. Is it recommended to have the windshield tinted as well. Do you find that helps a lot with glare? If I do the windshield, it seems that 70% is the recommended amount? Is the rear window also already tinted?
Insurance never cover any third party installed options, like tint or wrap.You are correct, no one can control when a rock chip will happen. No one can also control an accident either but that is why we have insurance as well so things can get fixed and repaired.
The rear glass is darkened but not specifically treated to reject IR (heat) the same as the rear passenger door windows. The top glass is factory treated to reject UV and IR. Maryland has strict rules re tinting. You cannot tint the windshield except for the top 5 inches (known as the AS-1 line.) The driver or front passenger windows tinting must have a minimum of 35% light transmittance. (A 65% or commonly 70% tint (barely noticeable) is OK, a 50% tint treatment of the front windows would not.)I'm also thinking of at least getting the front windows tinted to match the rear windows. Is it recommended to have the windshield tinted as well. Do you find that helps a lot with glare? If I do the windshield, it seems that 70% is the recommended amount? Is the rear window also already tinted?
