@John mclean There is a recalibration procedure to hold the window down button for 30 seconds, then up for 30 seconds. This recalibrates the force sensors at the stops.When I open my drivers door sometimes the rear near side window also drops. A my ideas?
If this only happens when you open your driver door from the INSIDE, then odds are you're hitting the window switches accidentally as you're opening your door
As someone who swore up and down that I had a defect only to begrudgingly acknowledge that I was the one accidentally hitting the window switches and lowering them, I will also say that the error is most likely the driver accidentally and unknowingly bumping the window switches; either while driving or while getting out of the vehicle.I got in the habit of closing the windows as I leave the car because more than once they were left slightly open just from resting my arm there.
There's a setting for that...I got in the habit of closing the windows as I leave the car because more than once they were left slightly open just from resting my arm there. I did this in my old cars too. When you are driving on the streets you don't always hear they are open, but on the highway it is more obvious, and I'm almost always just on the streets.
I'll have to look for it. It wasn't all that important. And besides, when you forget the app will notify you.There's a setting for that...
John, do you happen to have a procedure on how to calibrate the windows, I do noticed it also on my model Y, I am not sure if the door has to be close or open and should I hold the switch down for 30 sec@John mclean There is a recalibration procedure to hold the window down button for 30 seconds, then up for 30 seconds. This recalibrates the force sensors at the stops.
BTW, all windows do drop an inch when opening to clear the door frame. When you close the door, they go back up. I'm sure you are not talking about that, but if so....
Let us know if this procedure (given to me by Tesla) fixes the problem!
Yes, I found the setting a few months ago as I stated above.the windows close automatically when the car locks.
1) Hold the window down button for 30 seconds,John, do you happen to have a procedure on how to calibrate the windows, I do noticed it also on my model Y, I am not sure if the door has to be close or open and should I hold the switch down for 30 sec
Yes mine does this only in cold weather, otherwise they do not....Have you only noticed this since the weather has been getting colder out?
There is a ”feature” that lowers all the windows just a tiny amount when the weather is cold out. It does this to prevent the windows froze freezing to the windows frame, and also to prevent damage to the window if it does freeze and is unable to lower automatically when the door is open.
Nit sure this is what you’re hearing, but just a thought.
