Kind of an interesting dilemma I have run into.
The other day the coolant low warning came up as an alert. I checked for leaks and the level was in the normal range but still the warning existed. I Also checked the ground points on the front frame rails. Tried a full 12v and main battery power reset. MCU reset etc. Still the warning for low coolant.
I put it off a few days but now as the temps dropped to sub zeros I have found that the battery heater does not come on. It turns out that if the battery temps are too low then the car will not attempt to charge *at all*. It also turns out that if the coolant is low (supposedly) the car will not allow the battery heater to come on. This then in turn leaves you with a car that simply will not charge in low temps yet will not fire up the heater.
Tesla is sending out a new coolant sensor (entire reservoir) and I hope this fixes the issue. I have 60 miles of range left and no way to warm the batteries enough to charge!!
I understand the logic and the need to protect the battery heater from damage or fire but an override might have been cool. This could leave someone stranded in sub zero temps with a dead tesla over a $50 sensor.
