Hi Julien,I have found it to be all 3 at different times. So how do I vote?
And this is the reason it is often too fast or too slow and can't just be sped up or slowed down. It seems to me that in very misty or very small drops it sees it as poring and runs too fast. When the drops are large (even if raining harder) it is then too slow to respond. So I find:....Not sure if everybody knows but instead of the usual dedicated sensor for rain Elon decided to make the wiper function integrated with the neural learning and base it on the same camera used for AP. So far this has not proved a great strategy in my opinion but remain hopeful.
Hi Julien,
The poll cannot be updated once it is started. I didnt think of this possibility so I suggest you refrain from voting. My goal is to understand if there is a consistent bias towards to slow or too fast - because that would presumably be a relatively easy fix for Tesla.
Solving the "sometimes too fast and sometimes too slow" is much harder and maybe something that will improve over time as the neural learning improves.
If you do a quick press on the button at the end of the stalk (same one for windshield washer) it will do one swipe. I often use this if the auto wipers aren’t keeping up. My issue is they’re usually too fast or not quick enough to respond on auto.The wipers are one of the few downers in the car. The auto setting is consistently too slow to react and clear the window. I end up having to switch it to manual on the screen. This functionality is very awkward and should in my opinion be on the stalk. It is so bad I am wondering if I am missing something in how they operate ?
i'm with you but i think my biggest complaint about the variability in the wipers is the tendency to want to clear off the windshield if there's water when you put it in drive. every time, it puts the wipers in full speed and then continues to wipe until every speck of water is gone. i hate wipers on a dry windshield and it can't be good for the blade.I have found it to be all 3 at different times. So how do I vote?
Correct - I mean the frequency of wiping moreso than the actual speed of movement across the windshield.Not sure if you mean how soon the wipers activate to respond to rain, or whether you literally mean the sweeping speed of the wipers. I will assume the former.
