A little birdie told me the two connectors in question are for ethernet connection.
That's a bummer.
That's a bummer.
That's a bummer.
It would seem strange that Tesla would use Ethernet (or include two connectors) when generally the console computers are connected to by serial buses like USB. That being said, there are two NVIDIA Visual Computing Modules (VCM) in the car, so it doesn't seem out of the question (both ports--one per VCM--would have to be connected to a Ethernet hub or router).
Note: The stuff I pointed to is the development platform, so not what's in the actual box behind the touch screen.'
I guess at the end of the day we'll have to just wait for you to "open 'er up" to see what the connectors are for--if you're going to pull it out of the dash anyway, maybe you can just disconnect it completely so you can remove the metal casing and get some detailed pictures of the board and components (that will tell you a lot more than just the connectors). As for removing the touchscreen, I think you'll have to start pulling out large chunks of the dash. I'll be stopping by the Service Center this week or early next to pick up my car, so I'll see if I can ask the adviser for a tour of the place and see if any vehicles are ripped apart (supposedly the one I'm going to, which is in Van Nuys, is the 3rd busiest in the country).
Other pictures of the Jetson development board:
http://blogs.nvidia.com/wp-content/uploads/2013/03/NV_Jetson-Bottom-blackweb.jpg
http://blogs.nvidia.com/wp-content/uploads/2013/03/NV_Jetson-Edge2-black2.jpg
http://blogs.nvidia.com/wp-content/uploads/2013/03/NV_Jetson-3qtr-black.jpg
http://blogs.nvidia.com/wp-content/uploads/2013/03/NV_Jetson-Edge-black2.jpg
I'm not so sure I want to pull the touchscreen out of the dash without some professional guidance or assistance. I may be intrepid about these kinds of things but removing the touchscreen seems over the top for me.
Not a warranty item you want to void. Probably worth several thousand bucks.
$6,000 for a new touch screen as per Tesla.
Why?
For uploading quickly?
I'm back from China and all of the parts I need to finish the work on the front camera set up were awaiting when I returned home. At the very least I'll be able to rig the front camera for some tests this weekend. I won't be able to finish the PCB (have to make a few changes in the design) but I should be able to get some photos up showing the exact front view on the touch screen. It should take another week to complete final front camera set-up and make it all controllable from the touch screen.
Glad your back pal and cant wait to see the progress....Any idea how we can handle the reverse image?
I'm setting it up so the switch from rear to front camera will be made via the touchscreen. For now, both can't be on at the same time. But down the road a solution might be possible to have both on, with image each covering half of the touchscreen. One step at a time...
I meant the rear camera your using for the front, wont it be backwards when looking at the screen, cause its made for a reverse camera?
I wonder how distracting this would be when trying to pull in "straight" into a spot...Misunderstood.
For now there doesn't appear to be a way to flip the image on the horizontal plane, but for parking purposes, when all we're concerned about is hitting obstacles that might damage the front bumper, my case I don't think it matters very much.
Rick, have you determined if it's the camera or the VCM that does the image flip? If the cam, then if we could get another cam that's compatible with the screen, we could get around that problem right?
