X: What's your 90%?
scottf200
3,770
3,326
Chicagoland ModelX S603
Similar to the Model S thread: What's your 90%?
I just got my X. Supercharged to 90% showed 224 mi (224/9*10=248.88)
Image: http://i.imgur.com/XAIjBL1.png
jomo25
2,105
224
Scottsdale, AZ
I think there is still vampire drain, even if plugged in overnight. It will only draw power to top up after the charge state drops below a certain threshold below your target. So, your 90% might be 226 or 227 and dropping to 225 by the time you drive the car in the morning.
pvogel
917
199
Santa Clara, CA
Pretty sure I read in the manual or in "Owning Model S" that when the Tesla is connected to the EVSE all internal systems pull from that rather than from the battery
Reactions: Sean So Lowe
jomo25
2,105
224
Scottsdale, AZ
My condo's electrical billing system shows real time energy consumption for each unit. And my charger in the garage is billed/tracked/monitored as a separate unit. It's clear from the usage graphs that no current is drawn after the car reads its desired charge target. If these car is left sitting plugged in for a few days, then it'll top up after a while (about once a day) at the current rate set. Then it sits idle again. So that would contradict the behavior you are quoting from the manual.
Reactions: Behind
Mark Z
1,842
1,300
North Orange County
When new, my P90D Model X was 225.
After 3 months and 2,000 miles it is now at 223.
Almost the same range as the 3 year old Model S P85 version "A" battery pack with 45,000 miles.
scottf200
3,770
3,326
I was away last week and each night it did this for 22 minutes. SOC 67% -> 70% and Range 165.2 -> 173.4 (8.2 Miles - vampire)
I'm not sure why it skipped Thursday the 17th. I thought I had it starting at 1am so I also don't know why the times varied. Data from teslalog.com
Image: http://i.imgur.com/tSBbRyS.png
Image: http://i.imgur.com/n9nLOme.png
araxara
S-P85#3,218 X-LR M3AWD
May 11, 2012
1,012
380
Tucson, AZ
Picked up my Model X 90D (not P). Car was charged to 90% and the rated range was 238 miles. Car is currently at bra/tint installer, so can't check it, but Tesla app now says it has 234 mile range left. Car had 18 miles on the ODO when I picked it up.
