yet another regen thread
AnOutsider
S532 # XS27
Apr 3, 2009
11,957
200
In my typical usage it is on the order of 20%, according to the VDS.
so, just to understand, let's say you got 200 miles on a charge (just saying). Do you really get 160 miles and the regenned miles (20% = 40) make up the rest? Or do you get 200 and then an extra 40 on top from regen?
dsm363
Roadster + Sig Model S
May 17, 2009
18,278
151
Nevada
I believe it's already figured into your estimated range. It has a bigger effect in the city of course than the highway.
NielsChr
266
3
Denmark
so, just to understand, let's say you got 200 miles on a charge (just saying). ?
It really depent about how you are breaking....if you can forsee the breaking you can awoid using the break pedal and only relay on the motor break (regen).
But if you are forced to break fast you need to use the break pedal (energy lost due to heat).
If you teoretically can drive 200 miles (without breaking at all) - then lets prettend you are driving and some times need to slow down or stop, then you may only gain a range of 160 miles (without any form of regen)
(my own ICE goes down from 12 km/l at highway to 10 km/l in city - this is a reduction by aprox 15% due to more offen breaking in the city)
Tesla is regenerating kinnetic energy using the motor break (you are lifting the gas pedal, while the motor is runing in reverse as a generator) . I asume that it would be posible to regen up to 70% of the energy if ONLY using the motor breake (the last 30% will still be lost as heat).
if you are in need of breaking faster than the motor break is cable -you will need to use the break pedal together with the motor break - then maybe only 10% of the kennetic energy can be regenerated, wasting 90% of the break energy into heat (mostly in the break discs instead)
Doug_G have mention in above post that a typically regen value of 20% is posible in daiyly use.
I your math this will be:
160 miles + regenerated energy (20% of the 40 miles loss) = 168 miles total range.
How much your energy regen rate will be, really depent about how fast you need to break. If you can forsee the trafic in good time, and having the time to only use the motor break, you might be able to regen more than 20%. if you are waiting until last chance to break (using the break pedal) you may loss more and regen less than 20%. - what the practically max value is for regen, I really can not say, since I do not have a Tesla my self - mayby Doug_G knows ?
fast/offen breaking = less range
slow breaking = more regen, less loss
not breaking at all = max range
BTW: Tesla Model S 160, 240 and 300 miles range has already pre calcuated som breaking in the range - since this is messured as a standard driving pattern - making it posible to compare cars, Model S and roadster are using same pattern as ordenary ICE's cars
AnOutsider
S532 # XS27
Apr 3, 2009
11,957
200
Ok, I'm actually a bit more confused after that than I was before. Put simply, the ideal range quoted, is that WITH or WITHOUT regenerative braking? It sounds like it's WITHOUT, so if I do a lot of regen braking, then I can theoretically get MORE miles.
If so, that's great, as I'm a 1-pedal driver when the conditions permit.
William13
1,003
86
South Bend
The ideal range is supposed to be using the EPA standard course which does involve coming to a stop many times but I don't know if the breaking is at a proscribed rate. The acceleration is proscribed. Tesla historically has been accurate to conservative versus others(Leaf and Volt).
dmckinstry
Model X 2019
Jul 9, 2011
1,428
1,853
Medical Lake, WA (near Spokane)
More than you get by using the brakes, but not as much as if you don't slow except for your final stop. That is, never letting the brake pads touch until the end of your trip.
speedy99
Model 3 (2018, LR)
Aug 15, 2011
57
5
Santa Cruz, California
I use my Roadster as a daily commuter, mostly freeway. My VDS shows 10% regen. As an aside, in my experience driving with a light foot (and at/under freeway speed limits) will get more range than aggressive regen attempts, though I rarely have to brake.
Doug_G
Lead Moderator
Apr 2, 2010
17,881
3,351
Ottawa, Canada
I don't really know; obviously you could fudge a really high number by accelerating and decelerating continuously. I suspect my regen ratio is fairly high, as I don't drive on highways during my daily commute.
The point of regen is that it recovers most of the energy when you're forced to stop or slow the car. It doesn't extend your range so much as recover range that you would have otherwise burned off by braking. If you could drive continuously at a constant speed, without ever braking, then you would go farther.
AnOutsider
S532 # XS27
Apr 3, 2009
11,957
200
Is the energy lost by braking, or by the acceleration after the braking?
Doug_G
Lead Moderator
Apr 2, 2010
17,881
3,351
Ottawa, Canada
Let's assume we're starting at a fixed speed, slowing to a stop, and accelerating back up to the original speed again. Let's look at how much energy is lost compared to not stopping, and I mean "lost" in the thermodynamic sense: how much useful energy is converted to unusable waste heat. For the purposes of this discussion I am arbitrarily assuming the drive train is 90% efficient both in acceleration and deceleration.
If you have to use the friction brakes, then 100% of the kinetic energy is lost while braking. But of course you have to replace that energy when you accelerate back up to speed again, and with 90% efficiency you lose another 10% while accelerating. So you lose 110% of the original kinetic energy of the vehicle.
If you use regen, then some of the energy is "spent" decelerating, and some of the energy is "spent" re-accelerating back up to speed again. You lose 10% of the original kinetic energy slowing down, and another 10% of the original kinetic energy accelerating back up to speed again. So the total loss is on the order of 20%.
In this example, regenerative braking is 550% more efficient than using friction brakes. Energy is lost both during acceleration and deceleration, but in different amounts in the two scenarios.
Further Regen question
When I let off that little pedal on the right I can watched my total kwh used decline. However, on several occasions on long decents I have witnessed a total kwh used decrease in excess of 500 wh (over 2 Ideal Miles) yet the Ideal Miles indicator does not increase. Any of you experience this and why doesn't the Ideal Miles increase?
Doug_G
Lead Moderator
Apr 2, 2010
17,881
3,351
Ottawa, Canada
I suspect you're into the "error bars" for the battery capacity measurement. I've "lost" two km just backing out of the garage.
Mycroft
Life happens
Jun 18, 2011
1,599
54
On my boat
I don't know if it's been mentioned before, but I like the safety feature of regen braking. In an "emergency" braking situation, your car has already begun braking before your foot even has a chance to hit the brake pedal. The heavier the regen, the better!
Doug_G
Lead Moderator
Apr 2, 2010
17,881
3,351
Ottawa, Canada
I don't know what you mean by "error bars" please explain. The two or three times I've done this decent I had already driven ~75 miles so the battery had a little more than half the charge remaining.
In science, any time you make a measurement you also need to record the estimated errors. When you plot the data you usually include "error bars" for each data point on the graph, showing the likely range of values including the measurement error.
Basically I'm saying that 2 miles is probably on the order of noise in the measurement.
