I want the tire to stick a bit past the rim to prevent curb rash.
That picture is from the Martian Wheels Facebook page, so I'm not sure on the size. They only have 18" and 19" wheels on their website... Might be 19" and lower profile tires.
I did photoshop the picture to turn the wheels gloss black. They were gray in the original. I wanted to see what the gloss black would look like on my red Y. I liked the look a lot, so that's what I ordered. It will be at least a month till I see the wheels. The 45 offset and the gloss black are both special order items. I wanted the 45 offset to match stock geometry, and to keep the tires in the stock location. The rims should be "sucked in" 1/2" more than stock, but the outer edge of the tire should match stock. This way I should be able to use chains without worry and not change factory alignment. (Of course, the 1.75" lift I'm installing will require an alignment...)
