Exactly backward. The 18s without the hubcap look like a junk knockoff of a split spoke. With the hubcap they look like a 90s Caprice
Funny enough- I used to own a 90s caprice... a 1995 Impala SS specifically... after mods it was quicker than most cars Tesla makes (though not all of em) and the stock wheels were quite lovely.
https://www.cruisinclassicsinc.com/galleria_images/414/414_main_l.jpg
Tsportlines are nice, but they're actually heavier than stock 19s or 20s.
Sure but at least you get better looks for the cost/weight.
With the Tesla 19/20s you just get heavier and more expensive for a less attractive wheel compared to the uncovered aeros.
They're not uglier, clearly we are at a subjective difference.
Then, subjectively, they are in fact uglier.
But again- I said YMMV from the start about looks- you started in on the flat no to that
But once again, it's a 3.5 pound delta between wheel/tire combo from 18 to 20. I wouldn't be surprised if the 19s weighed less than the 18s.
Now, see, that's a flat no.
The 19s are 3.5 pounds heavier per wheel than the 18s.
The 20s are heavier again.
The Tesla Model 3 Wheel and Tire Guide
3.5 per wheel from 18s to 19s... 7 lbs per wheel from 18s to 20s... that's 28 lbs of added unsprung weight.
And you don't even get a wider tire for your trouble or $4000 cost.
18s without aero covers are 21.6 lbs per Tsportline...the 19s are 25 lbs... so 3.4 lbs more, per wheel, of unsprung weight.
The 20s are 28.75 lbs... another 3.75 pounds each of unspring weight. So over 7 lbs per wheel added going from 18s to 20s. Plus the much higher cost of the wheels themselves, and eventual replacement tires... plus, uglier
You keep talking about wider tires, that will make the 18s heavier, with the most weight at the edges, which is worse for rotational mass. So if you're concerned with weight (which at these numbers is insignificant), you wouldn't use wider tires.
If you look at youtube videos, it seems the 20s are actually faster than the 18s.
Which videos, specifically, compared them on the same car, same conditions, and most importantly
same tires?
So weird you think they're ugly, but nothing I can do about that.
Ditto with you thinking the 19s/20s aren't of course.
