Thanks again!
Good luck! Let us know how it comes out, hope it all works out ok.
Thanks again!
All L2 charging is slow at about 1/10 C. There's no difference between slow and really, really slow.I would also think slow would be best.
It would be interresting to hear about this car, about the battery and range etc.OK all IT IS CHARGING!! Just logged 3 miles using 110V.
It will take a fe day at this speed but most likely better for the battery.
MUCHOS GRACIAS!!!
absolutely I will!!!It would be interresting to hear about this car, about the battery and range etc.
Could you report back when you know?
now up to 4 miles per hour charge, currently 78 miles
This all is rather fascinating. Everybody knows about the background discharge of a Tesla due the computer running Sentry, keeping the door locks accessible, and so forth. And there’s been stories of people running the car dry with the heat or A/C on, or doing some YouTube exploit to see how the car reacts when the battery goes all the way down on a drive.now up to 4 miles per hour charge, currently 78 miles
I'm sorry, but this is just full of lack of knowledge of the Tesla architecture.This all is rather fascinating. Everybody knows about the background discharge of a Tesla due the computer running Sentry, keeping the door locks accessible, and so forth. And there’s been stories of people running the car dry with the heat or A/C on, or doing some YouTube exploit to see how the car reacts when the battery goes all the way down on a drive.
But that’s not this case. As a guess, sitting in a garage, no random pings, wi-fi off, and everything genteely discharging.
I think I’ve heard that a Tesla HV battery has a contactor in there that disconnects under the right circumstances. Which might be low charge, when disconnecting wouldn’t be a bigger disaster (as in running from a tidal wave, or not freezing to death). IF that’s true, there’d be two things going on:
This is pretty much gibberish.Usually, what kills batteries is when one has a bunch of them in series (as in, for example, the six cells in a 12V battery) and, as one is discharging them down to parade rest, some cells, due to manufacturing variations or what all, have more charge than other cells. So, at some point, the weaker cells discharge all the way, then start running substantial current on a fully discharged cell. That’s something that the wrecks the weak cell from taking a charge later and is why fully discharged 12V batteries are usually toast.
Hi, that's me. What happened here is that the 12V discharged long ago. The contactor on the HV was open, and the HV battery was at a fairly low SOC. But Teslas reserve about 5% of the pack at the bottom for this very case. So now there is no load on the Lithium battery except the internal BMS, which maybe draws 1W. Which might seem high, but you have ~4kWh of battery left before you do any damage to the cells. So you have thousands of hours to run the BMS. Plus, the BMS, if well designed, goes to very low power when the SoC gets low, possibly even completely off. So there really is no load on the battery, only self discharge. Self discharge is very low when you're at low SoCs.Fascinating. I really want to know if this battery comes back from the dead. And if there’s a real battery guy out there, any thoughts?
The contactors disconnect every time the car sleeps. And connects when it wakes up.I think I’ve heard that a Tesla HV battery has a contactor in there that disconnects under the right circumstances.
When you discharge a battery to to lower end (”0% SOC”) and stop the discharge the cells will recover voltage after the load has been taken away (as happens when the connectors open).Which might be low charge, when disconnecting wouldn’t be a bigger disaster (as in running from a tidal wave, or not freezing to death). IF that’s true, there’d be two things going on:
- Self-discharge, where the (non-linear) internal resistance of the battery provides a path for current flow backwards through the internal cells, discharging the batteries down to squat.
The BMS never let the cells ”fully discharge” (people might interpret that term different).
- Residual charge. Even with a fully discharged battery, there’s a bit of voltage across the battery terminals, caused, more or less, by the differences in electron speed in the anode and cathode materials. (One sees stuff like this with P-N diodes and thermocouples. And is vaguely related to how solar panels work.)
We can be pretty sure that Teslas BMS shut down the battery when the lowest cell reach the lower voltage limit.Usually, what kills batteries is when one has a bunch of them in series (as in, for example, the six cells in a 12V battery) and, as one is discharging them down to parade rest, some cells, due to manufacturing variations or what all, have more charge than other cells. So, at some point, the weaker cells discharge all the way, then start running substantial current on a fully discharged cell. That’s something that the wrecks the weak cell from taking a charge later and is why fully discharged 12V batteries are usually toast.
I would not be surprised if the battery is as fresh as it was before these two years.Wouldn’t surprise me if a bunch of cells are dead. But if any were, well, shorted, like the way a 12V battery dies, would it take a charge at all?
stacks of 48V lead-acid batteries, went all the way down. Most of the battery plant had to be replaced.
As long as the cells did not go way to low in voltage, the battery would have the least degradation in this state.The only real questions at this point are:
1. How much has the battery capacity been permanently reduced by sitting at low charge for so long?
We do not know that but as we know that the BMS most probably disconnects when the lowest cell group reaches the low limit and battery cells that are in rest regains voltage and also have very low self discharge ( in practical terms self charges a little), we can expect that the time from shut down until the cells get damaged from overdischarge is very long.2. Was any cell group damaged more than others that will lead to the battery going irreparably out of balance?
Um. FWIW, while not being a true-blue battery guy, I have been involved in Telecom faults where, without city power, the CO battery backup, stacks and stacks of 48V lead-acid batteries, went all the way down. Most of the battery plant had to be replaced.
