2021 Center Console Retrofit
You just update gateway config ID 106 to 2 (BLACK_CONSOLE_2 for black interior) or 3 (WHITE_CONSOLE_2 for white interior).
It is worth noting that apparently in cars that came with the 2.0 Console from the factory there is an additional wire that turns the wireless pad on and off. This is not present on cars that didn't come with the console, so the wireless pad is always on while the car is awake, whether there is a phone present or not. Changing the gateway config to tell your car that it has this console will make it act like that wire is there, which could lead to problems.
I have not received any errors or alerts or noticed any problems, but I'm just mentioning it.
Once you change that config value the car and app will show your car as having the 2.0 console.
Thank you for giving this information. It is very helpful
Reactions: Durzel
Have you confirmed that it's actually trying to turn it on and off? I imagine if the below entry is set to "NONE_OR_USB" (which I imagine pre console 2.0 cars would be set to by default), it shouldn't be trying to turn them on/off.
Code:
{"accessId":105,"codeKey":"wirelessPhoneChargerType","content":
{"enums":[
{"codeKey":"NONE_OR_USB","description":"Charger either not installed or USB type","value":0,"products":["Model3","ModelY","Poppyseed"]},
{"codeKey":"FRONT_LIN","description":"LIN-based inductive charger","value":1,"products":["Cybertruck","Model3","ModelY","Poppyseed"]},
{"codeKey":"FRONT_AND_REAR_LIN","description":"LIN-based inductive charger","products":["Lychee","Tamarind"],"value":2}]}
Code:
{"enums":[
Didn’t know about the existence of that key until now ☺️
That’s probably good then, because it means the behaviour of the wireless charger is perhaps independent of the “type” set.
I Just did this today! AMA. Console 2.0 to 2019 M3 LR. Got data working with an Amazon ordered USB hub https://www.amazon.com/dp/B0CL7C4B6S?psc=1&ref=ppx_yo2ov_dt_b_product_details Plus need a Mini USB B extension cord. Use the existing Data cable on the floor of the old center console (car harness to extension cord, extension cord to USB hub in console.) Everything works, confirmed.
Those of you having the USB sentry mode issue - I think I’m +1 to the group 😫
Is the issue everyone is having that the drive doesn’t show up at all? I have tried a USB-A thumb drive in a hub (worked previously) and that is not working, and I ordered a USB-C thumb drive to try that directly in the console port and still not getting anything to show (no option to format, etc)
FWIW I have a T-parts data hub in my 2.0 console.
I am on 2024.8.9 and have FSD.
Do we really need to change the "wirelessPhoneChargerType" after we retrofit the console 2.0? The wireless changer is work very well at least for one year after I use the new console expect it is very warm when I chager my iPhone. I plan to change the config ID 106 only for the UI.
I've only changed the config ID 106 - I didn't even know about that other configuration option until afterwards. Not noticed any issues with charging my phone on either pad, or seen any alerts to suggest there is a problem.
Reactions: Merchant Zhang
I successfully changed the config from the coding man. It shows the console 2.0 in my app, but the cars ui are not. Whatever the AC control. Or the car ui. It still in console 1.0. I identify it from the door panel. The coding man said it may need to rsync for a some time but not sure. I will update later if it get refresh.
Hi, I can't really see your second image very well.. the resolution is too low.
The car UI for the AC control doesn't change, there is only one console UI for all cars for the climate section. This confused me at first as well.
Take a look at this YouTube short to see what I mean:
..on that video (which is a car that came with the console 2.0 as it has a heated steering wheel, etc) you can see that the console graphic shows the two chrome "bars" down either side that isn't there on the new console.
OK it make me much clear now for the climate section. the pitcure I post is the car ui door panel part. For the console 2.0 I though it should have the wood trim decor. I don't know if it should have or not.
Oh I think I know what you mean.. that it should have the bit of wood extending on to the door card?
I guess the question would be - does anyone with the console 2.0 from the factory have the wood showing on the door? It is possible they don't. The door card looks so dark in the image you provided that it makes me think that it looks the same for everyone?
Tesla does this sometimes.. as has been said on another thread the rear brake lights are the same on all cars even if you have the newer "C-style" brake lights.
Doesn't show on the in car UI but does show in the app
I did the center console swap on my 2019 SR+ over the weekend. Sourced the console on ebay (managed to find one local to me for $311 picked up) and used MekedeTech USB Data Recovery Module Hub for Tesla Model 3/Y 2021 2022 2023 Central Control,4 USB Ports & 2 PD Fast Charging Ports 35W 65W Modification Car Fast Charging Box Retrofit Accessories for the USB data hub replacement. Moved the USB cable from my 1.0 console over to 2.0, did not need the mini USB extension cable. Everything went smoothly when using the picture guide that was on page 9 of this thread. Not worried about getting the interior of the car updated on the app. Not having any issues with sleep mode and i am on 2024.20.1.
Reactions: PauliePucks
Is your usb sentry drive working well with this hub? I feel like my T-Parts hub is no longer among the living, as I do not get any custom lock sounds sentry footage etc showing on my thumb drive. Which port is used for data on this hub, is it one of the usb-a’s? I have the same model 3 and year, so hoping this might be a solution.
I ordered the hub a bit ago and all 4 usb-A ports support Data and about 12 watts of power. The USB C ports are directly wired into the electrical pin out and can do 35+ watts each (no data). I haven't tested the 65watt single port claim tho.
It could be me....but it seems like after 2 days the hub just gave up lol. My sentry/dashcam drive stopped showing up (red X on camera). I have the TParts hub on order......
