2021 Model X, Monroney Sticker Range Increase
ElectricIAC
Devil’s Advocate
Dec 31, 2019
2,192
518
DFW
Tis indeed a mystery! Here’s my take: H has higher usable capacity around 105 kWh due to improved chemistry. But Tesla handled the change by decreasing the Wh efficiency number instead of changing the pack energy size. Either because they are lazy or don’t want to start a “capacity gate” and change the 100 kWh battery spec. If you think about it, this is an easy way to handle the larger capacity. Just change make the efficiency figure better, so SOC is depleted more slowly. I think Tesla increased the capacity instead of improved efficiency because the software update notes said “more accurately reflect the battery capacity”.
If Tesla in fact did this, then my long drive test won’t answer the question. The consumption numbers will be too low! For example it will show 10.0 kWh consumed when in fact it’s 10.5 kWh. If true, I am unhappy with this change since the energy meter is wrong, I am an engineer and numbers are sacred, I need to be able to trust my tech. I hope it’s a bug and they fix it. The only way we will know is to test a new cell or insert an energy meter between the battery and motors.
The P105D lives.
Reactions: BM3B
BM3B
“beaver”
Mar 8, 2019
703
847
Los Angeles, CA
I have one small data point on the pack size, I will try to get more data soon. The following data is from TeslaFi with no adjustments, I am not sure if the efficiency multiplier is correct, it may need to be updated.
98.63 mile continuous drive, consumed 122.79 rated miles, used 30.34 kWh battery or 33.0% of the battery.
This translates to 247 Wh/rated mile constant, and 91.9 kWh usable battery capacity.
I will try to do a long continuous drive and record the data both from the X trip and teslafi. I may need to change the rated mile constant, seems too low.
Reactions: ElectricIAC
_jmk
313
214
Finland
Too inaccurate for any meaningful data. The usable portion is 97.8kWh for the G pack (and probably F).
BM3B
“beaver”
Mar 8, 2019
703
847
Los Angeles, CA
Can you share data (evidence) please? I have heard 92 kWh usable drive capacity from an expert, charging capacity (I measured 101 kWh) is higher due to electrical losses, and physical capacity (102-105 kWh not confirmed) is highest due to software-controlled buffer.
The datapoint is not the best, but it is a useful datapoint until people share more info.
_jmk
313
214
Finland
Evidence is on your consumption tab. Do the math: (consumption * range remaining) / soc. Number is most accurate if the soc is 100% immediately after long balancing. Result is Whs of energy in your pack.
BM3B
“beaver”
Mar 8, 2019
703
847
Los Angeles, CA
Yes, I am trying to find time for a 265 mile straight drive from 100% down to about 10%. I have the -H battery pack.
BM3B
“beaver”
Mar 8, 2019
703
847
Los Angeles, CA
I did a long continuous drive yesterday from 100%.
Used 287/370 rated miles
Used 72.8 kWh from 100% to 22.4%
gives 93.8 kWh discharge capacity (72.8/287/370) and 254 Wh/rated mile.
Average speed 75 mph, peak 88 mph for an hour roughly. 2:40 drive
ohmman
Plaid-ish Moderator
Feb 13, 2014
9,895
17,891
North Bay, CA
How did it compare to the MCU energy graph while driving? I have found a discrepancy between them and do not trust the IC numbers, even when continuously driving and not using auxiliary power.
Remember that rated consumption is 284Wh/mi, which is evidenced by the line on the energy graph.
BM3B
“beaver”
Mar 8, 2019
703
847
Los Angeles, CA
Yes the system rated mileage is 284 Wh/mile (dashed line). But I have been told by @Bighorn that it is well known to experienced testers that the actual rated Wh/mile is different than that line in all Tesla’s.
The system Wh/mile (360) matched TeslaFi (360) exactly. What do you mean by IC? Internal computer? Yes this matched. 202 actual miles using 72.8 kWh is 360 Wh/mi. No discrepancy apparent to me yet. The energy graph looked correct though I didn’t study it. @ohmman I am very curious to see your data from the long days with several long legs per day towing in your new LR++, can you post them here?
284 vs 250 is a big difference. I suspect that the 371 mile range is just EPA gaming/ tuning. And the reason why -H got the additional range and not -G is that -H got EPA official testing so they can use the longer range number. I think the extra range is due to removing low Regen, which my wife prefers to use!
BM3B
“beaver”
Mar 8, 2019
703
847
Los Angeles, CA
Anyone with -E or -G battery back willing to do the same long drive test from 100% and share the data? Then we can compare to see if there is any difference.
Also as you can see I charged to 100% and got 370 miles.
ohmman
Plaid-ish Moderator
Feb 13, 2014
9,895
17,891
North Bay, CA
The system Wh/mile (360) matched TeslaFi (360) exactly. What do you mean by IC? Internal computer? Yes this matched. 202 actual miles using 72.8 kWh is 360 Wh/mi. No discrepancy apparent to me yet. The energy graph looked correct though I didn’t study it. What do you think?
IC = instrument cluster. I am talking about the trip app, which you used. It reports differently from the energy app, which appears to make more sense.
TeslaFi estimates energy consumption based on rates miles consumed with a 1/3 mile granularity.
BM3B
“beaver”
Mar 8, 2019
703
847
Los Angeles, CA
How can I get useful full-drive data from the energy app? It only shows efficiency for last 30 miles. Next drive I will compare the Wh/mi on IC to app. It was similar, I never noticed a discrepancy but I will check. Why would they be different? Which do you think is more accurate? IC should be accurate.
ColdWeatherEV
39
131
Northwest Wyoming
Interesting. I've been looking at my data, but from the charging information. I charged from 38% to 80% yesterday and Tesla indicated 42.7 kwh added. So 42.7 kwh / 42% = 101.6 kwh. I plan to do this for the next few charging cycles and see how they compare. Any readers out there with a scan my tesla app and an OB2 adapter that can hook it up to a car with the H battery? I'm curious what the BMS is reporting as capacity.
_jmk
313
214
Finland
It would be pointless comparison as those numbers depend on the discharge load, temperature, stops taken, ....
  • Disagree
Reactions: BM3B
BM3B
“beaver”
Mar 8, 2019
703
847
Los Angeles, CA
Wrong. We are measuring usable battery discharge capacity. The Wh/mi will depend on all those factors you listed. But not the discharge capacity if you so your math correctly.
BM3B
“beaver”
Mar 8, 2019
703
847
Los Angeles, CA
You measured charging capacity, which is always larger than discharge by 6-10% due to drivetrain and motor losses. I measured 101.1 kWh charging capacity.
