@GetYourWheelsI know there are aftermarket wheel vendors active in the forums, would love to hear your views as well
Not completely related but I took my OUT OF WARRANTEE 2016 S in for service and they told me they couldnt work on the car DUE TO AN AFTERMARKET STEREO!!!!! I had to elevate this and then had to sign a disclaimer that the "modification" may cause issues (BS) with the repair work and they were not liable for further damage (it was a cinch motor replacement)As per Tesla service advisor, It is NOT covered under warranty since the aftermarket wheels caused the issue. While they couldn't tell me the exact reason, they kept on telling me that "aftermarket wheels which is totally different from OEM caused the issue" MYP OEM Size is 21X9.5" Front, 21X10.5 rear 255/35-21 Front, 275/35-21 Rear.
Total cost with parts and labor - $2.6K
Anyone had similar issues before ?
Elon was most definitely NOT A FOUNDER...BTW, Tesla Inc. Is not just Elon. He is one of the many of the founders.
I was going to say the same as others, basically throw on OEM wheels and go to a different SC instead of wasting time trying to fight it with this one (you might need lawyer involved), but 200 miles is a bit far.Mine was 20" inch wheels with 275 40 20 tires ( wheels weighs 24 lbs than the heavier uberturbines) compared to oem induction wheels with 255 40 20. You are correct Tesla allows to select Square set up from Service Menu. Going up to 265 or 275 on oem induction wheels has been a popular upgrade for many here.
Not sure whom to talk to other as my next service center is 200 miles away
Rather worthless anecdote as impact speeds, angle, vehicle load, exact point of impact, among a host of other factors, would be different for every single car that hits the pothole. The number of variables here is so great that it's beyond silly to bring this up as some sort of evidence of anything . . . recommend taking Sixth Grade science class again.Actually I disagree.
As far as Fact proof here is a pothole example:
91 freeway after rain, crazy pothole, no less than 7 cars, 2 of them Tesla with stocks rims hit before I did, they all flat tires and or/bent rims. I didn't see and was on AP, BAM it felt bad but I kept going and drove by all these cars (2 teslas for a fact had stock rims).
Yes, and M&M almost destroyed Tesla due to their remarkably inept management and cost control, or so it appears . . . .Elon was most definitely NOT A FOUNDER...
Martin Eberhard and Marc Tarpenning founded the company. Elon invested in the company and then fired them (just like every venture he's done)
Bigfoot agreesyeah not a chance in hell aftermarket wheels and tires caused a steering rack failure
As well as every other car manufacturer out there with people putting after market wheels on. Most likely it was a defected part from the factory
And yet Tesla allows and has no problem with someone playing video games steering the car while parked for hours on end with no effect? Cough.I think it just has to be reasonable. they don't need to have an engineering analysis. i think it's reasonable to conclude wider/heavier wheels and tires will cause added stress.
You had to do the math to figure out 20mm is 20mm? InterestingI ran the numbers in a calculator, it seems your 275 tires have a significantly larger contact patch vs the stock 255 tires.
