this happened to me on aftermarket wheels 20x10" +40 offset with factory sized tires 255/40/20. luckily i had a friend of a friend who used to work for Tesla and he pretty much did what you said above. noise is long gone and i've driven at least 5,000 miles since. I didn't hear the noise when i had 21" factory wheels and tires.@globalmax Sorry, we gotta call the respective Tesla Service Center out on this one. We've had multiple chats with drivetrain & test engineers in the Tesla inner circle who've been there over a decade give us insight to grinding, squeaking, bouncy bed noises coming from the axles (with or without aftermarket wheels). They seem to think the noise comes from dry bearings or stretched out axles, and they have heard noises like this it countless times on completely stock vehicles.
1. This noise is common in many cars, and more so across the entire Tesla lineup. We as owners are just quick to notice it because EV's are quiet, but again this is common in ICE vehicles (it's just not as noticeable because there's engine noise). In our opinion, and those employees mentioned above it is a coincidence that you're hearing this grinding noise after you put on your aftermarket wheels and tires on.
2. Charging ~$2,600 for a steering rack & labor is an easy way for the respective Tesla Service Center to blame the aftermarket (because that's easy to do) and say pay up or be on your way.
3. HERE'S THE FIX (aftermarket wheels or not):
A. Get the vehicle on a lift and remove wheel(s)
B. Remove the 32mm axle nut
C. Lightly/carefully hammer back the axle toward the drive unit until there's about a 15mm gap
D. Lather the bearing hub or axle with anti-seize lubricant. Don't be shy, lather it up!
E. Push the axle back in
F. Tighten to 245nm (straight from the Tesla service manual )
G. Noise fixed.
Tesla’s video was massively overdone. Supposedly the actual amount of movement to play a video game is tiny amount IRL.I was watching a video on that the other night and cringing at the thought of the wheels being cranked back and fourth while sitting still. That is a LOT of force on the rack and rod ends. Especially for the Performance models with 35 series tires..
True, but really they only have to prove it if you sue them.As others have said. They have to prove that your wider contact patch caused the rack damage.
Yes I know but with a normal car company you could call customer service or a rep for the western region or whatever location you’re in and escalate it and maybe get a goodwill repair.True, but really they only have to prove it if you sue them.
Isn’t contact patch mostly a function of tire pressure, because Physics?You had to do the math to figure out 20mm is 20mm? Interesting
This exercise (lawyer + professional witness) will likely cost more than the$2600 repair, so why bother.It’s documented now that it was denied for x reason. Putting oe wheels on will look like a fraud claim. I’d suggest pay and sue in civil court with a professional witness on stand.
My 2022 MYP has aftermarket wheels with 20x10 wheels, 275 40 20 tires. Less than 8K miles so far. As far as I know this is pretty popular set up. Sold by leading aftermarket brand here (I am not convinced the wheels caused the issue. Don't want to say the brand so as not to damage their reputation or sales. It is well known brand and active and helpful with so many wheels specifically made and sold for Tesla)
Been getting grinding kind of noise from both sides at the front. Initially thought it could be the upper /lower control arms issue but this noise is not jut a
squeak but real loud. Had a service appointment at Tesla. As per them, Steering Gear Part#1044831-00-H to be replaced. As per Tesla service advisor, It is NOT covered under warranty since the aftermarket wheels caused the issue. While they couldn't tell me the exact reason, they kept on telling me that "aftermarket wheels which is totally different from OEM caused the issue" MYP OEM Size is 21X9.5" Front, 21X10.5 rear 255/35-21 Front, 275/35-21 Rear.
Total cost with parts and labor - $2.6K
Anyone had similar issues before ?
I agree that technically anything other than OEM can cause the issue and manufacturer can deny warranty. What are my options?
Also just a FYI to folks looking at aftermarket wheels
LOL there's plenty of space upfront for 275. Tsportline does offer 275 squared setups and a lot of tesla owner do that for their summer set. 275 upfront does not cause a failed steering rack.I do think if you put 275's up front, you would be running a much larger tire on an already tight space... T-Sportline has packages that are running no larger than 255 on the front to match the manufacturer width. If you were rubbing and making the steering rack push into fenders as well as the larger contact patch, that would certainly put the rack under strain. I am new to Tesla ownership but have owned lifted trucks/jeeps for years and dealt with steering rack issues from improperly sized tires or other factors from the mods. (specifically my Tacoma with 33's really didn't like the factory steering rack or the NAPA replacements... I had to go to an aftermarket heavier duty unit to keep it from failing every couple of years).
To agree with E46MYLR, how are the fender liners looking?
Best of luck! I'm about to go to an overlanding setup on my 22MYP - I'll post photos when complete.
As an attorney, I can tell you that a lawsuit against Tesla on this issue will run you well over $5000 in legal fees and court costs. Why? Because, Tesla has deep pockets and will hire the biggest law firm to paper your lawyer to death with endless Motion to Dismiss motions, thereby running up your legal fees.This exercise (lawyer + professional witness) will likely cost more than the$2600 repair, so why bother.
That might not work because the SC he took it too might have left notes about the issue in their system.don’t have the stock wheels to swap out and take it to tesla?
Wonder if your steering rack absorbed it rather than sacrifice the wheelActually I disagree.
As far as Fact proof here is a pothole example:
91 freeway after rain, crazy pothole, no less than 7 cars, 2 of them Tesla with stocks rims hit before I did, they all flat tires and or/bent rims. I didn't see and was on AP, BAM it felt bad but I kept going and drove by all these cars (2 teslas for a fact had stock rims).
LOL. not how it works really, would have thought if the timeline was there but it wasntWonder if your steering rack absorbed it rather than sacrifice the wheel
And what was their advice?That's being said, TSportline's advice is probably the simplest solution for you right now. If you still hear the noise, then you'll have to decide its worth paying Tesla for the "repairs."
@globalmax Sorry, we gotta call the respective Tesla Service Center out on this one. We've had multiple chats with drivetrain & test engineers in the Tesla inner circle who've been there over a decade give us insight to grinding, squeaking, bouncy bed noises coming from the axles (with or without aftermarket wheels). They seem to think the noise comes from dry bearings or stretched out axles, and they have heard noises like this it countless times on completely stock vehicles.And what was their advice?
