aerodyne
2 of 3 EV's - Defect Free!
AgreedI think your rated constant is probably like what you say, around 239 Wh/mi. Because if we assume that is correct, then your threshold value would be .239x405 = 96.8 kWh, which is consistent with what others are saying here.
Sounds about right. YTD is 227 wh/miHowever, to get actual miles roll off to match rated miles roll off, you would have to drive at .955x239 = 228 Wh/mi. Is that about what you are seeing?
Yes. 93.1, climbed back from like 88 last fall, current RM 390-392Is your current pack capacity below 96.8 kWh now? In other words, are you seeing degradation in rated miles?
Have the new screen, but don't use it since SMT gives the same data.Is the old original energy screen that shows projected miles remaining not available on the display anymore?
