SucreTease
Teslarian
This thread has been hijacked for discussions completely unrelated to the topic of this thread. Please take such discussions to their own thread.
Some of the topics have been marginal for sure, like the standard EPA range & method complaints, but I think generally discussions about capacity are still in the ballpark of the OP:This thread has been hijacked for discussions completely unrelated to the topic of this thread. Please take such discussions to their own thread.
2021-2023 MSPs had a rated range of 396 with a wh/mile constant of 244.6. The new EPA rating of 359 should be using a constant of 270 wh/mile but 279 is used instead making the displayed rated range at 100% 347 miles.
This is not an issue with the battery. My new MSP battery is displaying 96.9 kWh Nominal Full Pack which is normal for a brand new 99.4 kWh hour battery.
So either it's just a bug and they're using the wrong constant, or their actual EPA rated range is 347 and they're incorrectly stating the EPA rated range on their website. I'd like to think it's the former.
That is pretty impressive. Even your lifetime of 271 Wh/mi gets you almost exactly the official EPA rated range estimate of 359 miles.The 227 wh/mile in my Plaid is better than the 335 wh/mile I got on the same route in the MSLR loaner but the temps were warmer today (in the low 80s the entire way).
This is equivalent to 427 miles from 100% to dead.
Ruined by two trips to the snow. Steadily coming down. 267 as of this afternoon.That is pretty impressive. Even your lifetime of 271 Wh/mi gets you almost exactly the official EPA rated range estimate of 359 miles.
Possible side effect of trying to avoid driveline vibrations?You bought this Plaid so you could coast it and squeeze best possible mileage like the early Prius owners?
This isn’t how it works. 99.4 includes 4.5% buffer. ~97kWh as the maximum you can calculate is just the degradation threshold.
Energy app but not sure requisite info is available in Model S.What is your method(s) for calculating or otherwise obtaining the 97kwh number?
As we do not have the energy screen with average and calculated range, we can use SMT.What is your method(s) for calculating or otherwise obtaining the 97kwh number?
95,2 kWh 627km
95,0 kWh 626km
94,8 kWh 624km
94,5 kWh 622km
I drive in chill all winter to save the studded winter tyres.Just for kicks, I might commute once in Chill mode just to see being sedate improves it. I wasn't trying to be efficient. I just had meetings all morning on the way to the office and just sort of drove on auto pilot (me, not the car).
To clarify the method for a (very) large charge then for @aerodyne :As we do not have the energy screen with average and calculated range, we can use SMT.
Some things to consider in determining what constant should be used to calculate rated range.
1) EPA tests based on just one or two cars, with several thousand miles on them. Not exactly representative to the car you might have.
2) Using the EPA data of KwH drawn from the pack, I get rated consumption of 98.267 KwH /405 miles = 242.26 wh/mi. This does not agree with either Teslafi, SMT, or by calculating energy used on a drive, and comparing to nominal on the energy screen.
Using those methods, my rated consumption is about 238-239 wh/mi. ('22 MSLR)
3) It appears the rated consumption, at least in my case, is based on nominal full pack of just under 97 KwH, as stated by others.
It is rational to assume the Tesla deliberately used a lower number for pack capacity to calculate consumption than the EPA test data suggests, to account for tolerances in manufacturing, hence a higher rated consumption.
The older palladium cars reported to have a non usable buffer of approximately 1.5 KwH. This would be about the same as 99.4 - 97 kwh.
Because of the first two points, I would use SMT to divide the nominal remaining capacity by the remaining range over a period of time, to get the rated consumption.
Not having a newer plaid, not sure if this answers the question posed by the thread title.
There probably will be very minor differences between two different cars in the manufacturing line.Some things to consider in determining what constant should be used to calculate rated range.
That calc is off. They did get a lot more than 405 miles range in the test, they got 554.7 miles.2) Using the EPA data of KwH drawn from the pack, I get rated consumption of 98.267 KwH /405 miles = 242.26 wh/mi. This does not agree with either Teslafi, SMT, or by calculating energy used on a drive, and comparing to nominal on the energy screen.
Well, for the kWh number, the battery starts it calendar aging as soon as the car is built and this rate is quite fast initially, so to make it possible to ship the car, deliver it and getting the owner to be able to see anything close to the full range at least once there need to be a margin for the degradation that happens.Using those methods, my rated consumption is about 238-239 wh/mi. ('22 MSLR)
No.The older palladium cars reported to have a non usable buffer of approximately 1.5 KwH. This would be about the same as 99.4 - 97 kwh.
SYes, if you have SMT. This seem to set the number at 96.7-96.8 kWh, just like another Swedish Plaid in post #91Because of the first two points, I would use SMT to divide the nominal remaining capacity by the remaining range over a period of time, to get the rated consumption.
I guess there will be an update with new firmware, like my M3P 2021 had the old 499km/310 miles for the first months until it was changed to 315kmi/507km like the EPA.The primary question posed by this thread is this:
Has any owner of a 2024 Plaid with 19" wheels seen their car display a range of 359 miles (as advertised) at 100% charge (equivalent to 287 miles at 80% charge)?
All people with the above car that we know of show only 347 miles of range. This implies that Tesla used the wrong constant in the firmware for the exact vehicle described above. This thread was created to discuss this exact problem and very little of the discussion has been about this problem.
I understand. And those people with 2024 Plaids are free to weigh in on that issue here, but for some reason they are not. Maybe not many people are buying 2024 Plaids, or they just put the display on percent and don't pay any attention to the rated miles.The primary question posed by this thread is this:
