Yep, that is what I am saying.
Looked, not sure what you are referring to exactly. You can link it if you want.
Sure. That is what I am saying.
The point is that at 99kWh you’ll see 97kWh in the car if you are not using the CAN bus. Everything is just scaled directly in a straightforward way, of course you still have the 99kWh; it just does not display that way.
Yes, sure. Agreed, when new. That is what I am saying. It will look like 97kWh and the buffer will be 4.5% of 99kWh and the usable will be 95.5% of 99kWh.
You’ll start losing miles as usual below the degradation threshold which I am told is about 97kWh (see
@AAKEE for more info).
I don’t know what they used to do but they don’t do this now. 0% is ~4.5% of the capacity remaining AFAIK. Right at the buffer.
