I called a local trailer park/campground - they gave me the cold shoulder. They only want to deal with overnight guests... welcome to Florida :wink:
Even for 5 minutes of charging for a few bucks? Talk about easy profit for them.
I have tried resetting the cord. Neither of the two lights over the buttons light up - just the top one goes from green to flashing green/red.
When I press the reset button, the fault light on the cord briefly flickers on then remains off.
Only problem is that connector is right in front of the front door and probably always has a non-ev parked in it (at least the one or two times I went there was.)
PEM line fuse? What were the symptoms?
How do I do a GFCI test on the UMC?
I recently had an electrician install a NEMA 15-50 to use the UMC I bought 2 years ago when I got the Roadster (I've been using the 120V charger the last 2 years). When I plugged in the UMC, the car charged for about 10 minutes and then stopped for a minute or 2 before resuming. It did this for about an hour which the Tesla ranger was here (I wanted someone here the first time I plugged in). They took the UMC with them and tested it but it looks fine in their outlet. They pulled the logs and say that my voltage is fluctuating too much. I am literally 5 feet away from the electrical box in the garage. So I am not sure what my options are at this point. An electrical engineer friend is going to measure the voltage this week to see if he sees anything. He mentioned I may need a voltage stabilizer but those run close to $1k if you want to do 50 amps. Any ideas? Is there something other than the voltage I should be measuring?
It's the responsibility of your electric service provider to provide you with clean power. If you voltage is fluctuating you should call them and they are required to provide the correction. I had a similar problem to find that there was a co-gen plant nearby that was throwing spikes into the system. The co-gen operators had to make repairs to correct the voltage spikes they were causing.
Maybe you have a bad breaker or two (the circuit and/or the main), or the connection to the bus in the panel is bad ... beyond that, I'd think the electric company could check the lines to the house (they replaced mine for free when I was having some odd intermittent issues that turned out to be a bad breaker / bad connection in the panel). Would be interesting to know just how much it varies.
May also be worthwhile to reduce the amperage to see how much you can draw before it starts tripping.
