searching the forums about tires, found a lot of discussion but did not find the answer to this....
assuming the mx will NOT be used for towing, can the rear tires be replaced by 265/45 (same as front), keeping the oem 9.5 rims? has anyone done this?
the front has a bit lower load rating but i am guessing if towing not required, that should not be a problem.
