The reason the ground can be thinner is that it would only be used momentarily until the breaker trips, which would be very fast in a short situation, meaning there would be no time for the thinner wire to heat up. I mean, sure go beyond code if you want, but the electrical code is pretty conservative as it is.And the 6/3 is mainly for thicker ground over 38’ 6/2 would be cheaper but the 1mm ground not sure about.
Was hoping to do it myself both electricians are friends.
But yes I’ll look further Into rules possibly add part conduit. Where it’s touchable.
Thank you for all the help
I had no idea that US code and cable built was so different
I read so many posts satating 4/2 or 4/3 wire.
