Panasonic 2170L, the 82.1 kWh pack has a bit higher degradation rate than the first gen 2170.
Still, 81.9 kWh is very good.
Nominal Full Pack or Nominal Remaining at a full charge?
At average ambient temps you could expect to loose 5.5-6.5% or sometimes more the first year from calendar aging only when having the car above 55% SOC mostly.
Calendar aging is most rapid initially and reduces the rate with the swuare root of time.
With 6.5% first year, you would expect to loose ~ 3.75% the first four months.
78.4 out of 82.1 is ~ 4.5% so not very far from what to expect. The BMS could be out in the blue as well.
You could search for some of my numerous posts about calendar aging.
Calendar aging will be the thing that degrades the absolute most part of your battery for the first 8 year or so.
The most important thing is to keep the SOC at or below 55% as often as possible.
You can see that low SOC is better for reducing the calendar aging, all the way down to 0%. (But as 0% gives limited range, 55% displayed SOC cut the calendar aging to half but still offers 55% of the range. This is the sweet spot for range vs degradation.
The usual thing people have problem with is the low SOC part. The usual myth talk about not going below 20% but that is - right - a myth.
The battery is happy all the way down to 0%
For cyclic aging, we need to first remember that cyclic aging will only be responsible for a minor part of the degradation the first 8 years or so.
These cycles are from the voltage in the chart down to 2.5V ( = true 0%)
We can see that a lower charging voltage ( = lower SOC) causes less degradation.
4.2V = 100%
Then around 0.1V decrease = 10% which means that 3.7V ~ 50%.
This chart shows actual model 3 cells taken from a almost new model 3.
Cycled in 10% Depth of discharge in different SOC ranges.
If we look at the cycling range causing the most cyclic aging which is 5-15% SOC (this transfers to ~ 0-10% in Teslas display, as Tesla has a 4.5% buffer in the bottom).
In this case we loose ~17% after 3000 FCE cycles (which actually is 30.000 actual 10% cycles).
3000 FCE would be around 3000 x 250 miles real range so around 750.000 miles.
Still we only loose 17% so with an normal annual driving of ~ 12500 miles we would loose 12500/750.000x17 = 0.28% each years in cyclic aging. Despite cycling the battery in the very low end. (Which by the myths is said to be very bad to the battery)
So using the battery in a low SOC range will reduce both the calendar and cyclic aging.
I did use the low SOC stategy with my M3P 2021 with the same 82.1 kWh battery. I had a lot less degradation than most people, after 2.5 years and 66K km the battery capacity was 78.0-78.4kWh (last full charge 492 km range out of 507km).
The man owning that car now has not been interrested in using the low SOC strategy but it still has a good 76.8 kWh capacity after 3.5 years.
My BMS was on a bad estimation tour in the summer of 2022, but I did a 100-0% drive to test the capacity and it was 79 kWh at that time, so the correct range should have been around 498 km then. The dip seen is the BMS Being off.
I use the same on my ‘23 MSP, which still show full range after 1 year ownership and 20K km plus (97.1 kWh nomimal full pack today, close to what the most see as the top value.). Full pack when new = 99.4kWh but most packs show 97-97.5 kWh as the top value.
You do not need to worry about using full charge, that will not kill your battery.
Use full charge whenever you want/need to.
I did have more than 30 full charges on my M3P (exact number forgotten, but possible to check…I think 35) I also had around 55 Supercharging sessions on that car, still low degradation.
I have around 12-15 full charges on my ‘23 MSP and ~ 20 Supercharging sessions.
The car has very low degradation despite this.
Its not the full charges nor the Supercharging sessions that will reduce the capacity very fast. It is calendar aging that get the rate set by [SOC x Temperature].
