Duke-U
the splice piece has been wrapped with cotton tape to prevent it from rattling. The red/black wire goes to the new lights. This is the passenger side rear door.
Thanks, for the electrical connection, you just splice the pig tails to connect the light ropes and use the pig tails connection to connect between the factory harness and the factory ambient light? Sorry, I haven't opened the panels yet so I cannot tell how the they are connected in the back.
@pabla looks like the new lights are drawing too much current. Do both sides of the car go out, or only one side? The transformer/power box could be the problem, I had one that overheated and then short-circuit, causing one side of the car’s ambient lights go dark. See my post earlier in this treat.
edit: did you check on plus and minus? The pigtails have no wire indication which is which. If you mix up the new lights plus and minus then this could be the cause.
Yea mine are definitely less dull than yours. Are you able to turn the brightness fully up and see if any of the lights turn off? I just want to confirm this before I rip apart the door again to testThe line are a little more dimmed than the one under the door armrest. They do dim together if you dim the screen backlight. View attachment 636187View attachment 636188View attachment 636189
If you tap into the footwell lighting it won’t work when the ambient lights are turned on. On the S the footwell lighting is only turned on when a door is opened and turns off once you start driving.Hey so quick follow up. Is there a way to tap into the foot well ambient lights? Don't wanna do my doors just the dash and might be a lot easier to tap into those lights. And if so will buying those extender cables work? Thanks in advance
Ahh good to know. So the only ambient lighting on the car is the doors?If you tap into the footwell lighting it won’t work when the ambient lights are turned on. On the S the footwell lighting is only turned on when a door is opened and turns off once you start driving.
YesAhh good to know. So the only ambient lighting on the car is the doors?
