Hi
So I've noticed for quite some time during the summer, the AC fan would blow at 11 and then after 30 minutes the fan would still sound like it was blowiing at max but the air would not come out of the front vents,..as if it was blowing at 3.
I had the unit replaced after bringing it in one year ago as they couldnt figure out the cause, (theywitnessed the air not blowing at the service center)
The problem is still occuring. But hey... After probing around I saw some threads that said that the evap sensor develops condensation which causes this problem and the fix is to just turn off the AC and the fan will start to blow again. I tried this and it worked great. After 20 seconds the air was blowing at max and everything seemed to reset.
Anyone else here check out this fix? is the internal evap sensor need replacement or really just ok and this is a design flaw? At least there's a solution
R
R
