I bought some relay from Amazon:
ALMOCN 6Pcs DC 5V 1 Channel Relay Module With Optocoupler Isolation Support High or Low Level Trigger https://a.co/d/7eIX1hV
Pulled the cover below the rear ac vent area and added them. I got 12v from pin 1 and 26, signal also got it from one of the other pin and I tested that it did work when I close all doors and open one. The ooto coupler kicked in
However the output side has no voltage whatsoever. COM is positive load and NO or NC are negative load depending on whether you want it normally open or normally closed.
I tested this with a volt meter as well as some regular 12v led light. It won't light up at all.
I really like this relay bc of it's small size. Only if it works!!!
