Test for yourself while using cruise control or by viewing brake lights.
I have. I can pop an S out of cruise with no mechanical braking. A very light press on the brakes is all it takes. No braking engagement, and/or so little mechanical braking as to meet the pragmatic definition of "none", and cruise is long gone.
Everyone is entitled to their opinions, and I'd never try to convince you to "like" or "dislike" the pedal movements that I prefer in my other car. Nor am I stating that a Model S can (or even should) exactly emulate that behavior. All I'm saying is that, in that other car, I like the behavior. I may come to like the Model S way better over time. I do like the stronger deccel effect (feeling) in the Model S from full "lift the go pedal" regen.
At the same time as we have our various opinions, there is only one set of facts. And the statement that a Model S cannot sense the brake pedal movement prior to the engagement of mechanical braking is not in alignment with reality. I just drove the car a few seconds ago. Details:
1) Put the car in cruise at 30 MPH
2) Press the brake just enough to make the brake lights come on (visible at night on concrete behind the car)
3) Cruise instantly ends & car begins regen deceleration (because the gas pedal is up and cruise is off, not because the brake pedal is pressed per se)
4) Regen decel is medium strong at 30MPH, and central dial indicates 30kW or so of regen. Brake lights are still on.
5) As regen tapers to zero, so does deccel feeling. Brake lights are still on.
Car took few seconds to go from 30MPH to about 5 as the regen tapered away. The remaining 4 or 5 to 0 takes additional 17 to 22 seconds very level street. The last 1MPH to a full stop seems to take forever. Brake lights have been on since step (2) above. If I get on a slight down hill, the car actually rolls at 2 to 4 MPH as long as the hill lasts. Not stopping. Brake lights on, rolling along at 3MPH or so.
I can only state these facts for one 2015 VIN P85D on 6.1.blah.179 software. That car? It is dead easy to turn on the brake lights and knock the car out of cruise with no effective mechanical braking action.
