So down the road if I were to change to a T Sportline 20" wheel, How would I program the Y to know I changed wheel size. I currently have the 21 Ubers. I have seen some photos of a reset TPMS screen but it only offered the choice of 19 or 21.
And what make its more confusing is with the 21" Uberturbine the front and rear tires are different sizes! So do you have to do the same with after market and put 255 in front and 275 in back?I just replaced the 21s Überturbines with 20s - same diameter tires (255/40/20) - so the speedo reading should be same as stock.
I doubt that the Y actually senses the tire size, but relies more on to input via the Wheel Config (missing function as of yet) to predict range.
I am having this issue right now. The current software 2020.5.10.8 still does not have the Wheel Configuration or TPMS Learn function.
Apparently, if you use/transfer your current TPMS sensors - the Y still reads them.
What kind of wheels are these? They look amazing and I’m curious how they would look on a white PUP.
The 255 and 275 refer to the width of the tire, not the diameter.And what make its more confusing is with the 21" Uberturbine the front and rear tires are different sizes! So do you have to do the same with after market and put 255 in front and 275 in back?
I know. I guess the aftermarket solution is just go with all four thee same size.The 255 and 275 refer to the width of the tire, not the diameter.
what size tires are you running?I am having this issue right now. The current software 2020.5.10.8 still does not have the Wheel Configuration or TPMS Learn function.
