P3D-R
Closed
Thanks for the explanation. I get that the shaft is hidden behind the dust cover. My mistake.
Can you explain more why droop is more important for the street. I certainly understand needing that travel for a pothole, for example, but isn't compression travel equally needed for a bump?
I'm totally on board with the adjustable damper length not being important if it's properly designed and that it could be a liability if it's adjusted too low. In MPP's case, they've already defined that distance and in Redwood's case they set it for you to make sure you're not risking your battery hitting the ground. All things being equal, there's no difference there. You just adjust the spring perch up and down to set height in either one. As you lower the spring, the damper compresses, moving closer to the bump stop so that minimum clearance to the ground is maintained.
Here's the part I'm not understanding though. The MPP kit is designed for a 1" drop. If I want a stock ride height with MPP, I have to use a 1.75" lift kit which puts me above stock ride height. To get back down, I have to lower the spring perch by 0.75" putting me closer to the bump stop. Do I not lose 0.75" of compression travel by doing that?
Also, by designing the suspension for a 1" drop, do they not have to use a stiffer spring than if it was designed for no drop?
SORRY FOR THE LONG READ and if I've misspoken please do correct me.
We're definitely making progress here and you're proposing better questions imo. Just for record, I have the RW Ohlins kit and work next door to them. I love my kit and sadly couldn't make it the day that you showed up. I know Heath really wanted me to. I was hoping you were gonna come up from SLO on Friday but ended up coming Thursday. I did speak with MPP a month or so ago to setup an account and assist them in scaling inventory out here on the westcoast but was turned down because I have the RW Ohlins kit and they really want all their dealers to be exclusively MPP. I understand that but it's very unfortunate because I'm really good at what I do. I hope they can see that I'm not here to sway people one way or the other. I simply want consumers and the community to understand the facts behind the pros/cons of these various setups. Not only MPP vs RW but also these other companies that might start coming out of Taiwan to support our lovely chassis.
I do believe there is a benefit with the independent lower bracket if you're raising the car just because you don't need to purchase spacers. In MPP's case they are using spacers to effectively raise the car but since this is occurring above the uppermount it will not have any negative effect on the stroke. In fact I would prefer to position the piston in it's optimal position for the damper stroke and then "shim" with spacers above the mount to get the higher ride height where you want. This way you can retain the optimal compression and rebound stroke to make the vehicle feel right and without unsettling the chassis because there isn't enough stroke in either of those two directions. So kudos to MPP there.
I totally get it that having more droop than compression doesn't seem logical and many moons ago I thought the same thing. It's difficult to explain without an animation or maybe it's just too early for me in the morning. I believe MPP will have a much easier time to explain this because they're very good at their editorials. The epiphany came after installing "JDM" coilovers with the independent lower bracket for a good 5 years, between 1999 and 2004, and then getting a european car into the office with KW's that had this massive stroke and helper springs. I could literally fit my head in the wheel gap under full droop. I was like, "Why would you do this?" You lose all your compression travel. Well I installed the setup, aligned the car, then went for a drive. It was AMAZING!!!!! I was like, "Holy crap, what is this non-sense?" It defied all my childish logic. Granted I was in my early 20's at that time and hadn't gotten super deep into suspension theory. Up until that point I was just an electrical engineer that liked to build custom audio systems and drive RX7's very irresponsibly. One of the primary functions of the suspension is to keep the tire on the ground. I think we can all agree to that. Let's say you install some "JDM" type coilovers with an independent lower bracket and NO helper springs and maintain preload on the main spring. Then all ride height adjustments are done at the lower bracket. Since you haven't "drooped" that spring at all the droop will be determined how much the weight of your vehicle compresses that main spring under static load. Let's say that is 1" for ease of numbers. Well now if you were driving on the freeway and hit a decent dip it will compress the damper and then make the vehicle want to "launch" upward. If you only have 1" of droop you will get air time. When that tire leaves the ground and then inevitably makes contact again it will be a sudden impact versus a damper that has 2-3" of droop you allow the shock more time to absorb that energy and potentially never have the tire leave the ground. This is the simplest analogy I can propose to make it easier for people to understand why droop is so important. In fact droop is more important than bump. Also keep in mind that bumpstops are usually 1.75" in length so you have that much stroke always available if your bumpstops are in place. There's also a huge difference in the properties and quality of bumpstops. This is a topic that I'm sure MPP can provide a lot more technical data on. In fact I have some peers local to us in Fremont that have published some information to help bring some light to these topics. Granted a lot of these tuners will not give out all their secrets but at least it will start to open up one's mind to new logic. Take a gander and do some googling to continue your education. Even I after 20+ years am still learning everyday. FCM discusses bumpstops starting on page 20.
http://www.fatcatmotorsports.com/FCM_Suspension_Truth.pdf
