@zman222's post illustrates exactly why I chose to pass on the MPP comfort coilovers + a lift kit when I contacted them over a year ago about developing a luxury suspension kit for us. This photo of the rear shock clearly shows how it is riding directly on the yellow bump stop. This is the same thing that happens if you put lowering springs on the stock dampers and my experience with that was awful.
To have any compression travel, at least some of the rod should be showing!
Since the MPP dampers only have a spring preload adjustment, the only way to lower the car is by dropping the spring preload which reduces compression travel. So even though the car is at the OE ride height using the lift kit, the dampers are set to a dropped ride height and have lost a lot of what limited travel the Model 3 has. For the best possible ride, we need all the travel we can get!
On the other hand, the
@RedwoodMotors and Unplugged kits use threaded damper bodies. That way you can extend or reduce the damper body length independent of travel length. Now this can get you into trouble since you could have a combination of long travel and low height that could let the car smash into the ground, but you just have to be mindful of the safe ranges given in their installation guides.
I've ridden in a car with the Unplugged kit and there's no doubt it's a smoother ride than OE with more performance, but it's still performance first since it's using stiffer springs than OE because it was designed for a lower ride height. I'm sure the MPP kit has a better ride as well since they also use excellent components from KW, but that doesn't change the physics of that kit being designed to lower the car by 1" which means stiffer springs than they would otherwise have needed for a higher ride height.
That leaves the
@RedwoodMotors Grand Touring kit as the only option that was designed for OE ride height and full travel which lets them use softer springs for the (hopefully!) smoothest ride.
