dale_cooper
Niche M117
19x8.5 ET33
Conti Pure Contact LS 245/40/19
19x8.5 ET33
![4w83c4R.jpg](https://i.imgur.com/4w83c4R.jpg)
![0knovn9.jpg](https://i.imgur.com/0knovn9.jpg)
These look awesome for a pretty conservative fitment. Are you running any spacers on them? They look pretty flush.Niche M117
19x8.5 ET33
Stock height?Niche M117
19x8.5 ET33
Stock height?
Sounds expensive lol..Anybody rolling on TE37 ultra TRACK EDITION II 20x9.5 +30 at 20x10.5 +25? Not sure if it fits lowered on UP moderates and if the stud holes need to be enlarged to 14mm.
RAYS - The concept is racing. [en]
That should fit without any issues. However the Sema special just ended last week so they will definitely be pricey.
I have 255/40R19 on 8.5.... so even at with 9.5 it should fit fine height wise
Do you have a straight shot with the wheel and tire from the front? My setup is the same and I’m debating going 245 versus 255. TIAVS Forged VS14 in satin black 19x9.5 square setup. Weight: ~19.5lbs. Running Hankook Ventus V12 Evo2s 255/40/19. Ordered through Jason at GetYourWheelsView attachment 467645View attachment 467668View attachment 467669
Here’s a straight shot from before I lowered it. I don’t have any from after I put MPP comfort coilovers on.
thanks a lot....that helps. Wasn’t sure if 255 was gonna rub against the fender being lowered. I’m on T sportlines (inch or so) and if I needed a slight stretch. Wheels are coming in and don’t wanna rebuy tires if I guess wrong. How’s the wh/mi?
No problem. You’ll be good with the 255s.
Wh/mi for me took a big hit, but that was mainly because I started driving more spirited. I was averaging about 220 wh/mi with the 18” Aeros uncovered and now I average around 270. Again, I drive a lot more spirited than I was before. If I drive the same as when I had the 18” Aeros uncovered, I average around 240 wh/mi with my 19” wheels so about 10% range loss. Mostly, I am commuting ~120 miles/day in LA/OC area.
Well, like the title says i'm interested in seeing what different wheels people are throwing on their model 3's. If you have some aftermarket wheels, or have seen some in the wild, post a picture of what you got!
