Speedgirl
Great, thank you!! I appreciate your help!I’m on UP moderate 1.5” drop. Wheels are 20” 285/30 and 245/35 and clears easily. No rub at all. A few others on here have the same set up with no issues.
All,
Please bear with me as I couldn't effectively comb the 124 pages in this post, but was wondering if there is a reason most folks go with aftermarket wheels at 19" (or even 20"s) and not 18"s?
I've noticed that most of the 18" wheels are mainly for the winter setups but then folks switch them out to the 19" or 20"s for the spring/summer or even all season daily. I was looking to drop down from the 20" performance OEMs to an 18" for reasons other than pothole preventative issues (i.e. light weight, ride comfort, possible road noise, etc). However, since most of you all use the 19s or 20s for the non winter / daily driving I was wondering if I was missing something other than aesthetics?
Any help is appreciated.
Hope all is well,
AP
Looks good. What do those things weigh?
I'm a somewhat new Model 3 owner and am considering new wheels for my next upgrade. Is there anything special about the Model 3 that prevents me from just buying any ol' set of wheels and slapping them on? Can the Model 3 TPMS be added to any set of wheels/tires? According to the manual it looks like I need wheels with a width of 8.5", is that correct?
I have the 2020 SR+. What bore size should I be on the lookout for?depending on the model you have there's a center bore size difference, and wheels would either be that or a hub-centric ring is required. Some owners have mounted wheels without the hub ring, but most wheel dealers throw it in so I would rather use them than not.
Bore size is 64.1I have the 2020 SR+. What bore size should I be on the lookout for?
View attachment 528676 View attachment 528677
Here’s a couple pics I took today while doing some yard work. Stealth with 35% tint. 20” Vossen HF-5s on Micheline Pilot Sport A/S. 235/275. Tsportsline lowering springs.
MORREEEE!!!View attachment 536731
SSR GTX01 19x9.5 +35 5x114.3 sourced from AutoRnD in Fremont.
More information about before and after wheel weights/savings found here:
New wheels: P3D 20" vs 19" SSR GTX01 with 265's
Perfect stance. Can you share the wheel and lowering specs? also, how is the ride compared to stock?
Stance sf07 19x9.5 with 265 square
Lowered 1” tsportline on LR awd
Front is just flush. Looking forward
Looking towards the rear
